Suspending the fuselage for removal of the main gear
GalinHdz
PostPosted: Mon Apr 04, 2022 6:00 pm    Post subject: Suspending the fuselage for removal of the main gear Reply with quote
FWIW; I installed a 2x10 board on an adjustable sawhorse. I then covered the 2x10 board with thick moving blankets as padding. Then I lifted each wing, put one sawhorse about where the main spar is under each wing and lowered each wing down. This suspended the airplane so I could take the landing gear off and made it impossible for the airplane to fall down. You can see the setup in the attached pictures.
Remember to chock the front wheel during this procedure.
On Thu, Mar 17, 2022 at 3:08 PM jeffbudner <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)> wrote:
--> KIS-List message posted by: "jeffbudner" <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)>
Thanks Doug, for the good idea and posting a pic, that makes for a good model to follow.
Jeff Budner
KIS TR-1 # 099
http://forums.matronics.com/viewtopic.php?p=506335#506335
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?KIS-List
="noreferrer" target="_blank">https://matronics.com/contribution
 Filesize:  361.81 KB
 Viewed:  12682 Time(s)
 Filesize:  426.92 KB
jeffbudner
PostPosted: Tue Apr 05, 2022 9:53 am    Post subject: Re: Suspending the fuselage for removal of the main gear Reply with quote
Galin, thanks for the info and example. I took a similar approach, it worked well and I was able to safely and easily work on the main gear.
Best,
Jeff Budner
KIS TR-1 #099
GalinHdz
PostPosted: Fri Apr 08, 2022 5:44 am    Post subject: Suspending the fuselage for removal of the main gear Reply with quote
BTW, I forgot that I wrote down my method of lifting up a wing for maintenance and posted it on my webpage. When I needed to take the landing gear off, I used this procedure on both wings and it worked great. You can find the .pdf file at:
www.puertoricoflyer.com > MAINTENANCE > MISCELLANEOUS > "Jacking Up a KIS4 Wing"
On Tue, Apr 5, 2022 at 1:55 PM jeffbudner <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)> wrote:
Best,
Jeff Budner
KIS TR-1 #099
http://forums.matronics.com/viewtopic.php?p=506501#506501
jeffbudner
PostPosted: Mon Apr 11, 2022 5:15 am    Post subject: Re: Suspending the fuselage for removal of the main gear Reply with quote
Thanks Galin, I don't think I mentioned that I like your website, lots of good information. I downloaded the PDF, it's pictorially pretty complete and a good reference to how you accomplished the aircraft lift and support.
Thanks again,
Jeff
