Posted: Mon Jan 31, 2022 10:11 am Post subject: SURFACE MOUNTED THROUGH HOLE COMPONENTS |
I made a circuit on perf board with all components and wires on the top surface so that the perf board can be be fastened directly
to aluminum without shorting out. I glued the components to the board with E6000.
When completed, I coated everything with a layer of E6000. That keeps wires apart that are not supposed to touch.
The value of R1 determines setpoint. You might want to use a POT. The light comes on at about 13.2 volts.
Choose the value of the LED resistor based on the voltage drop of your LED.
I don't need this warning light because my EFIS warns if the voltage is low.
It was a fun winter project.
14.11 KB |
2756 Time(s) |
| Components are glued to board with E6000 |
24.92 KB |
2756 Time(s) |
| Wires that cross are spaced vertically |
21.7 KB |
2756 Time(s) |
| Everything potted with a layer of E6000 |
20.38 KB |
2756 Time(s) |
_________________ Joe Gores |
John M Tipton
Joined: 07 Aug 2018 Posts: 45 Location: Devon - England
Posted: Tue Mar 08, 2022 2:03 am Post subject: Re: SURFACE MOUNTED THROUGH HOLE COMPONENTS |
And: for a filament bulb, just remove the resister: yes !!!
