jlpartington(at)reagan.co Guest
Posted: Sun Jan 30, 2022 8:15 am Post subject: Mixture cable CJ6 |
I am finally finishing up the install on Doug Sapp's project motor I picked up as he closed down business.
I have been learning and relearning a lot and the end is insight.
I have seen this issue before but it has been so long (over 30 years) so I need some reminding.
The mixture cable is binding after about an inch of movement toward lean. The cable is retracting as seen from the engine. I see no huge/sharp bends in the tube, no worse than many that are working.
I am thinking it must be where the solid end meets the cable in side and a minor kink is restricting movement. How long are the solid rod ends? Perhaps that will help me locate the issue.
Or I am all wet! Any ideas, or helpful hints? I am sure that I am not the first.
Jim (Pooh) Partington
817.917.6806
