peterz(at)zutrasoft.com Guest
Posted: Sat Jan 01, 2022 12:43 pm Post subject: Mono tire size - debate? |
So i replaced my Airtrac 7.00 with an 8.00 during my frame repair, and am very happy with the larger tire. Better deck angle for landing, greater prop clearance, better on grass i imagine, no clearance or rubbing issues (i did however trim the throttle box a bit of excess height).
I do remember folks complaining about swing-arm rubbing, but I've not had any. Just a tiny but of caliper rubbing with new pads. Yet everyone appears to be running the 7.00 these days?
curious…..
PeteZ
h&jeuropa
Posted: Sun Jan 02, 2022 2:55 pm Post subject: Re: Mono tire size - debate? |
Pete,
When we started our test flying we had the 8.00 tire that came with the kit. We also used 18 psi as per the manual.
When we did testing at 1450 and 1500 lbs, bolts on the brake caliper rubbed the side of the tire, made a nice round groove in the sidewall! Hence the change to 7.00!
We never tested the 8.00 tire with more than 18 psi. Perhaps it's fine with higher pressure.
Jim & Heather
Posted: Sun Jan 02, 2022 3:06 pm Post subject: Mono tire size - debate? |
Indeed I’m typically running at 23psi….. no caliper groove, just a mark. Likely the difference then i guess
Cheers!
PeteZ
| Quote: | On Jan 2, 2022, at 6:03 PM, h&jeuropa <butcher43(at)att.net> wrote:
Pete,
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=505565#505565
ward.t(at)xtra.co.nz Guest
Posted: Sun Jan 02, 2022 5:03 pm Post subject: Mono tire size - debate? |
Pete,I operate my Air Hawke 7.00-600 at 28psi tyre pressure. Works well with 250mm prop clearance. (64” Props)
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
| Quote: | On 3/01/2022, at 12:02 PM, h&jeuropa <butcher43(at)att.net> wrote:
--> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net>
Pete,
Jim & Heather
<==============================================================================; - M-===================================================bsp; - NEW MATRONICS LIST WIK==========================bsp; - List Contribution Web S; -Matt Dralle, List Admin.
Posted: Sun Jan 02, 2022 5:13 pm Post subject: Mono tire size - debate? |
Hi Tim, thx for the data point!
How does it perform on softer turf?
PeteZ
On Sun., Jan. 2, 2022, 8:11 p.m. timward, <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
| Quote: | Pete,I operate my Air Hawke 7.00-600 at 28psi tyre pressure. Works well with 250mm prop clearance. (64” Props)
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
| Quote: | On 3/01/2022, at 12:02 PM, h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Pete,
Jim & Heather
<============================; - M-==========================bsp; - NEW MATRONICS LIST WIK==========================bsp; - List Contribution Web S; -Matt Dralle, List Admin.
Posted: Sun Jan 02, 2022 5:57 pm Post subject: Mono tire size - debate? |
No problems.
Tim Ward
12 Waiwetu Street
Fendalton
CHRISTCHURCH 8052
Hom 03315166
PeteZ
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Pete,
Jim & Heather
JohnFrance
Joined: 17 Sep 2014 Posts: 83 Location: Grenoble France
Posted: Mon Jan 03, 2022 1:21 am Post subject: Re: Mono tire size - debate? |
Hi all,
This debate is quite interesting, I am using a 7” Air Trac tyre with 22 psi on a Beringer wheel. I tried pressures around 28 psi but found the extra height made the aircrafts lateral stability or rather lack of it disturbing, especially on hard surfaced runways as the aircraft would teeter from side to side inducing yaw which is unpleasant (mono drivers will know what I mean). My outriggers are standard lengths.
_________________ Europa mono Nr 192 |
Posted: Mon Jan 03, 2022 6:15 am Post subject: Mono tire size - debate? |
Fwiw, i appreciate the higher deck deck angle to be able to stall it on, tail slightly first with less of a main wheel drop/bounce. I also enjoy the 4” (on a single side) outrigger clearance to be able to keep flying both off the runway when conditions allow. I guess the side to side teetering is a personal preference/objection
John, do you know if the 8” Air Trac can be used on the Beringer wheel? I’d love to switch….the stock caliper misalignment and poor wear etc is terrible.
Cheers!
PeteZ
| Quote: | On Jan 3, 2022, at 4:29 AM, JohnFrance <77alembert(at)gmail.com> wrote:
Hi all,
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=505573#505573
dmac7
Posted: Mon Jan 03, 2022 9:13 am Post subject: Re: Mono tire size - debate? |
Hello Pete, please be aware that many here will refer to the 800-6 golf cart tire when you inquire about a 800-6 tire. That tire bears no resemblance to the Airtrac 800-6. The Golf cart 800-6 dimensions varies depending on manufacturer. There have been some who used the Airtrac 800-6 on there Mono, Jos Okhuijsen, David Corbett, Remi G, and others. Remi wrote a article on the Beringer wheel and brake installation on the Mono and felt that it wouldn't work because Beriniger offset the wheel left .125" but I have the Beringer and Airtrac 800-6 4 ply it fits well. It is 1/2" greater dia. than the Airtac 700-6. It has 1/4" clearance on left side and 3/8" on right of Lg. Without a doubt the Mono handles different with air pressure changes, things happen slower at low air pressure.
dmac7
Posted: Mon Jan 03, 2022 10:26 am Post subject: Re: Mono tire size - debate? |
One point regarding the difference between a Airtrac 700-6 6 ply and a Airtrac 800-6 4 ply as it is 1/2" taller and a inch wider it will maintain propeller clearance when on soft ground, with the 700-6 I was sinking in the soft ground once after a rain storm, and almost took out the prop, a 800-6 will have more floatation. Originally Ivan had a 8:50-6 but with no suspension.
Posted: Mon Jan 03, 2022 11:25 am Post subject: Mono tire size - debate? |
Perfect… thx for the detailed info - much appreciated!
Im currently very happy with the airtrac 8 (at) 23-25psi on tarmac, and would love the beringer upgrade.
Thx again!
PeteZ
http://forums.matronics.com/viewtopic.php?p=505578#505578
