Posted: Mon Jan 31, 2022 10:15 am Post subject: MORE (Re: Weird primer leak) |
Looking at the video, it appears to be leaking out of the middle of the assembly. The only thing I can think of is if the little ball in the center behind the plate is corroded and stuck. If it’s stuck it may be the cause of the leak when you pump the primer.
Dennis
| Quote: | On Jan 31, 2022, at 1:08 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Look for cracks in the flare under the tubing sleeve inside the B nut.
Difficult to see unless you physically remove the B nut and inspect the tubing flare.
Dennis
> On Jan 31, 2022, at 1:03 PM, 1906 <zmadwolf(at)gmail.com> wrote:
> I have a leak from the back of the primer handle and it's been difficult to figure out. I might just end up replacing the whole thing but was curious if anyone has seen this before.
> The top b-nut is tight. I've taken a number of pictures and I can't see any cracks in the fittings or the tube.
> https://www.youtube.com/watch?v=TsxCMMe31co
> http://forums.matronics.com/viewtopic.php?p=505859#505859
