Audio panel move - 10/18/21
ronaldcox
PostPosted: Tue Oct 19, 2021 7:19 am    Post subject: Audio panel move - 10/18/21 Reply with quote
 ______________________________
Time: 07:58:47 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: RE: Re: Audio panel move
At 07:18 AM 10/18/2021, you wrote:
>I think I would find it much easier to make a short extension on the
>bench than to crawl up into the instrument panel with my soldering
>iron and various other tools, but that's only me, a very old fart!
   From one ol' fart to another, agreed. MUCH reduced
   chance for errors that are EASY to make and very
   difficult to find/fix.
   44 pin devices would be the sub-miniature D-Subs.
   Sorry. No inventory on that series of devices.
I used a couple of these (cut to expose the needed conductors) when installing my old Garmin in my Glasair panel. They screwed right into the Garmin tray and make great contact.
I know the insulation isn't aviation-rated. But for this use in a protected area, I just cant get too excited about it. (Especially in my somewhat-flammable airplane.)
Amphenol CS-DSDHD44MF0-005 44-Pin HD44 Deluxe D-Sub Cable, Shielded, Male/Female, 5', Gray https://www.amazon.com/dp/B00O072X3Q
The cable is plenty flexible, though a bit long. With a little looking, you can likely find something closer to just the length you need.
Saves a lot of crimping and testing, or just cut it and do one end. Probably costs about the same as 88 (plus re-dos) pins and a tool if you don't have one.
Ron
Ron Cox
Glasair Super II F/T
Under Construction at C77 - Still just about to fly!
