slingshot003
				 Posted: Tue Oct 05, 2021 7:15 am    Post subject: Kolb-List Digest: 2 Msgs - 10/04/21 |
				chic,
 Since your engine is behind the CG, if you raise the rear of your engine (direct some of your thrust downward) you will take away some of your forward thrust and add to your downward thrust, which in turn will cause the nose to be pushed up.  Picture a teetter-todder: the CG is the fulcrum; the engine is on the tail side; and the nose is on the other side.  If the engine is pointed down it will be pushing the whole teetter-todder downward, but since it is on the tail side, it is also causing the nose to go up.
 On Tue, Oct 5, 2021 at 2:39 AM Kolb-List Digest Server <kolb-list(at)matronics.com (kolb-list(at)matronics.com)> wrote:
  	  | Quote: | 	 		  *
  Today's complete Kolb-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the Kolb-List Digest and can be viewed with a generic text editor
  HTML Version:
      http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2021-10-04&Archive=Kolb
  Text Version:
      http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2021-10-04&Archive=Kolb
                             Kolb-List Digest Archive
                       Total Messages Posted Mon 10/04/21: 2
  Today's Message Index:
       1. 06:33 AM - Re: Fitting request  (Rick Neilsen)
       2. 10:48 PM - Re: Reducing power on take off versus thrust line.  (chic)
  ________________________________  Message 1  _____________________________________
  Time: 06:33:53 AM PST US
  From: Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)>
  Subject: Re: Fitting request
  Paul
  I have a Kolb MKIIIC. It is located at the Hart/Shelby County airport in
  Michigan. Take the Badger (car ferry) across lake Michigan to ludington and
  it is app 20 miles south. You are welcome to test fit in it. I'm heading to
  Florida for the winter Oct 21 so if you are going to check it out please do
  so quickly.
  Rick Neilsen
  Redrive VW Powered MKIIIC
  On Sat, Oct 2, 2021 at 7:49 PM prhutson <prhutsonwi(at)gmail.com (prhutsonwi(at)gmail.com)> wrote:
  > Is there anyone with a Mark III anywhere near south-central Wisconsin that
  > would let me sit in their Classic or Xtra for a fitting?  I am 6'3" but
  > longish torso.  Failed a fit in a Sonex today.  There was no one around at
  > Airventure this year when I stopped by for a fitting in a Mark III there.
  > Thanks!
  > Paul
  > Paul Hutson
  > Middleton, WI
  > http://forums.matronics.com/viewtopic.php?p=503382#503382
  ________________________________  Message 2  _____________________________________
  Time: 10:48:03 PM PST US
  Subject: Re: Reducing power on take off versus thrust line.
  From: "chic" <gcechini(at)msn.com (gcechini(at)msn.com)>
  Okay, so I am a little confused here..... If I raise (just) the rear of the engine
  on my Firestar 2 for more prop clearance off the boom tube, am I adding positively
  or negatively to the thrust line?
  http://forums.matronics.com/viewtopic.php?p=503414#503414
  WIKI -
  Click on to Richard's Blog:[/url]
 [url=http://godstuffrichard.blogspot.com]Thoughts On God And Life  -Prose, [b]Prayers, Poems & Ponderings      [/b]
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
