EGT issues hwo to troubleshoot best
werner schneider
PostPosted: Fri Jul 02, 2021 2:35 pm    Post subject: EGT issues hwo to troubleshoot best Reply with quote
Hi all,
wanted to update on that case, we did dismantle the plug and remove the
d-sub pins, could see, that part of the braid around the wires was
touching , did use shrinktube to cover the end and now the EGT4 looks
stable.
Thanks for the advices and help.
Cheers Werner
PostPosted: Sun Jul 04, 2021 6:58 am    Post subject: EGT issues hwo to troubleshoot best Reply with quote
At 05:32 PM 7/2/2021, you wrote:
--> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
Hi all,
stable.
Cheers Werner
Good detective work! Ain't physics wunderful?
out of that stuff?"
werner schneider
PostPosted: Mon Jul 05, 2021 1:38 am    Post subject: EGT issues hwo to troubleshoot best Reply with quote
Indeed, easier to detect then electronic gremlins with a logic approach to each and every component in the line.
Found on the annual as well the nicked field wire which in one flight probably caused an elevated voltage and hunted down a crimp on a fast-on which, after 18 years, was degraded to become a high resistance point (heating element). All fine now and plane back in the air with a good feeling for finding these points.
Cheers Werner
