Aileron stop inboard or outboard?
pplous(at)aol.com
PostPosted: Sun May 30, 2021 8:39 am    Post subject: Aileron stop inboard or outboard? Reply with quote
RV-8 Listers,
It looks like I need an aileron stop on the left wing to keep one of the aileron actuator rods from contacting the side of the hole it goes through at full stick throw. (I've already cut out the hole to the edge of the actuator support.) Van's plans show installing the stop on the inboard actuator bracket near where the actuator rod connects. There is another bracket, much easier to get to, on the outboard edge of the wing. Why not put the aileron stop there?
Thanks!
v/r,
P2
bifft(at)xmission.com
PostPosted: Sun May 30, 2021 8:51 am    Post subject: Aileron stop inboard or outboard? Reply with quote
Quoting PRESTON PLOUS <pplous(at)aol.com>:
RV-8 Listers,
Just thinking out loud here, but if it is closer to the push rod
you don't put a twisting force on the aileron when it hits the stop.
Brian Huffaker, DSWL
RV-8A N609HZ flying
Kellym
PostPosted: Sun May 30, 2021 8:57 am    Post subject: Aileron stop inboard or outboard? Reply with quote
Keep in mind that when you get ready to fly, you legs may serve as your
aileron stops, depending on your leg position relative to the stick. My
DAR worried about my aileron encountering a little interference at the
aft right position, on my -10, until I pointed out that even if Twiggy
were the pilot, you couldn't get the stick that far right. May be
different with your setup.
> RV-8 Listers,
  Just thinking out loud here, but if it is closer to the push rod you
  RV-8A N609HZ flying
Kelly McMullen
KCHD
paul(at)pkirby.plus.com
PostPosted: Sun May 30, 2021 10:20 am    Post subject: Aileron stop inboard or outboard? Reply with quote
https://vansairforce.net/community/showthread.php?t=168372
On 30 May 2021, at 17:43, PRESTON PLOUS <pplous(at)aol.com> wrote:
 RV-8 Listers,
Thanks!
v/r,
P2
Laz
PostPosted: Sun May 30, 2021 10:48 am    Post subject: Aileron stop inboard or outboard? Reply with quote
There is a much easier way to make a stop.  You make a nylon bushing that goes on one of the bolts.  Just search under Aileron Stop on vans forum there are lots of examples .
On Sun, May 30, 2021 at 12:53 PM <bifft(at)xmission.com (bifft(at)xmission.com)> wrote:
--> RV8-List message posted by: bifft(at)xmission.com (bifft(at)xmission.com)
Quoting PRESTON PLOUS <pplous(at)aol.com (pplous(at)aol.com)>:
> RV-8 Listers,
   RV-8A N609HZ flying
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV8-List
WIKI -
pplous(at)aol.com
PostPosted: Sun May 30, 2021 12:21 pm    Post subject: Aileron stop inboard or outboard? Reply with quote
Brian,
Makes sense. Keep unnecessary torque to a minimum. Thanks for your quick reply!
v/r,
P2
Preston Plous
-------- Original message --------
Date: 5/30/21 12:51 (GMT-05:00)
To: rv8-list(at)matronics.com, PRESTON PLOUS <pplous(at)aol.com>
Subject: Re: RV8-List: Aileron stop inboard or outboard?
RV-8 Listers,
   RV-8A N609HZ flying
Laz
PostPosted: Mon May 31, 2021 1:46 pm    Post subject: Aileron stop inboard or outboard? Reply with quote
That’s what I have on my  8 and it works great.
On Mon, May 31, 2021 at 7:34 AM Paul Kirby <paul(at)pkirby.plus.com (paul(at)pkirby.plus.com)> wrote:
On 30 May 2021, at 17:43, PRESTON PLOUS <pplous(at)aol.com (pplous(at)aol.com)> wrote:
 RV-8 Listers,
Thanks!
v/r,
P2
