Magnetism
bobbypaulk(at)comcast.net
PostPosted: Wed May 19, 2021 5:21 am    Post subject: Magnetism Reply with quote
When we were building two airplanes in a large hangar my rudder cables got relocated to a DC welding machine where they laid for several days while the welder was used several times. I located my remote compass to the rear bottom of the fuselage ( right between the galvanized rudder cables ). When trying to calibrate the compass it would swing wildly when moving the rudder even slightly. We tried degauzing with a solder gun and even found an old TV degauzing ring to no avail. Finally moved the compass up high above the baggage compartment and it worked fine.
