rick(at)beebe.org Guest
Posted: Sun May 09, 2021 1:03 pm Post subject: Current-based alternator noise |
I have two alternators in my plane. The original belt-driven one is 20 years old. I'm not sure what exactly it is--the log book says it's an ESI 32B19549. It's connected to a B&C LR3B voltage regulator. The second one is a B&C BC410-H mounted on the accessory case with an SB1B-14 regulator.
I get a horrid whine from the primary alternator. We discussed that a few months ago and it was suggested I check the grounds. I just finished my condition inspection and paid close attention to all the grounding and it appears to be good. All connections are tight with no corrosion. Measuring resistance from the alternator case to the fuselage is only a few milliohms.
The standby alternator is dead quiet.
In flight, the whine isn't too horribly noticeable over the engine noise except for when the strobes are on. Today I turned on the pitot heat and the whine when from whoop whoop to a constant loud whine. Normal draw, with strobes and landing light (which I always leave on) is about 13 amps. If I shut off all the lights the draw goes down to 11 amps and at that level the whine goes away. With pitot heat on it's 19 amps and the whine is constant.
Thoughts? Does it need to be rebuilt?
Thanks.
--Rick
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Sun May 09, 2021 3:31 pm Post subject: Re: Current-based alternator noise |
Check the AC voltage. It should be less than 1 volt AC
_________________ Joe Gores |
Posted: Sun May 09, 2021 4:27 pm Post subject: Current-based alternator noise |
At 04:02 PM 5/9/2021, you wrote:
Quote: | I have two alternators in my plane. The original belt-driven one is 20 years old. I'm not sure what exactly it is--the log book says it's an ESI 32B19549. It's connected to a B&C LR3B voltage regulator. The second one is a B&C BC410-H mounted on the accessory case with an SB1B-14 regulator.
Thanks.
--Rick |
99% of alternator noise issues do not
arise from a failure in the alternator.
The symptoms you describe are indicative
of a ground loop in your audio system.
out of that stuff?"
Posted: Sun May 09, 2021 4:37 pm Post subject: Current-based alternator noise |
At 06:31 PM 5/9/2021, you wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
Check the AC voltage. It should be less than 1 volt AC |
This check can be useful but it's not
all inclusive particularly with digital
voltohmeters that don't have an 'output'
function (built in capacitor in series
with the test lead).
Also, digital voltmeters don't resolve
AC to the native DC world as did analog
meters. Mass of the pointers in analog
meters produce an inertial averaging
function. Digital meters won't read the
same for the complex waveform that is
alternator ripple even if you add the
requisite capacitor to take out the DC
component.
This check goes to the possible but very rare
instance of a bad diode in the alternator.
Since this is a belt driven machine, one way
to check it is take it off and have it run
on a test bench at an alternator dealer or
overhaul shop.
An alternator with damaged diodes will not
deliver anywhere near rated output current.
out of that stuff?"
skywagon185(at)gmail.com Guest
Posted: Wed May 12, 2021 12:33 pm Post subject: Current-based alternator noise |
Could be a power diode failure.
On Sun, May 9, 2021 at 2:05 PM Rick Beebe <rick(at)beebe.org (rick(at)beebe.org)> wrote:
Thanks.
--Rick
