flyingphil2
Posted: Mon May 24, 2021 6:14 am Post subject: Noseleg assembly NG01 |
A bit of a random question.
I have a noseleg assembly - NG01 (see the rear part of this in the attached image). Should I be able to disassemble this by sliding the sub assembly off the main tube or is this designed to be a friction fit and unmoveable without great effort?
I'm concerned that there is corrosion between the outer noseleg tube and inner sleeves of the rear sub assembly, which is why I can't separate them to check, but maybe it's not designed to come apart?
Phil
863.25 KB |
2754 Time(s) |
peter.rees01(at)tiscali.c Guest
Posted: Mon May 24, 2021 6:56 am Post subject: Noseleg assembly NG01 |
If you’re talking about the leg and the articulating frame, they should be a good fit with loctite to hold them together (from recent experience of replacing both on HI).
| Quote: | On 24 May 2021, at 15:21, flyingphil2 <philipjtiller(at)gmail.com> wrote:
Phil
http://forums.matronics.com/viewtopic.php?p=502039#502039
http://forums.matronics.com//files/img_0863_620.jpg
