jonboede(at)hotmail.com Guest
Posted: Sun Apr 11, 2021 2:05 pm Post subject: Shower of Sparks |
IGN circuit breaker blows and won’t reset.
New M-14P on a CJ. Went to actuate the start solenoid for the first time now that the system has air on it again after a year of sitting.
I turned on the master and ignition and I heard the shower of sparks (from Chinese engine, worked great when I took that engine off) buzz. Then the ignition CB popped and won’t reset. Even if I turn off the master.
Any ideas on where to begin troubleshooting?
Jon
migfighter42(at)gmail.com Guest
Posted: Sun Apr 11, 2021 2:13 pm Post subject: Shower of Sparks |
Bad circuit breaker. Start there.
I’m guessing they are switch circuit breakers?
Bill Culberson
Red Star Aero Services
251/716/8119
| Quote: | On Apr 11, 2021, at 6:10 PM, Jon Boede <jonboede(at)hotmail.com> wrote:
Jon
Posted: Sun Apr 11, 2021 3:42 pm Post subject: Shower of Sparks |
For reasons beyond the scope of this discussion 🙂 I just happen to have a new ZKC-5 circuit breaker switch from Doug, which is exactly what the IGN switch is.
Previously I'd turned the switch on but hadn't pressed the start button. Today was the first press of the start button. I heard the shower of sparks buzz just before the circuit breaker popped.
So, the plan is:
- Replace the circuit breaker
- Disconnect the two canon plugs to the shower of sparks 2Q and start solenoid 3Q
- Press the start button and see if that causes the breaker to pop (bad canon plug somewhere maybe, wiring issue)
- Connect the 3Q canon plug and see if that makes it pop
- Connect the 2Q canon plug and see if that makes it pop
What would make a shower of sparks "go bad"?
Is a new shower of sparks "impossible to find" as I've heard?
Jon
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Bill Culberson <migfighter42(at)gmail.com>
Sent: Sunday, April 11, 2021 5:12 PM
To: yak-list(at)matronics.com <yak-list(at)matronics.com>
Subject: Re: Yak-List: Shower of Sparks
--> Yak-List message posted by: Bill Culberson <migfighter42(at)gmail.com>
Bill Culberson
251/716/8119
> --> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com>
> Jon
Posted: Sun Apr 11, 2021 4:30 pm Post subject: Shower of Sparks |
Remove the breaker and test it on the bench with an ohm meter. If it doesn’t reset after removal, replace the breaker. They can fail. Dennis
| Quote: | On Apr 11, 2021, at 7:45 PM, Jon Boede <jonboede(at)hotmail.com> wrote:
So, the plan is:
Jon
Subject: Re: Shower of Sparks
Bill Culberson
251/716/8119
> Jon
mail Forum -
ist">http://www.matronics.com/Navigator?Yak-List
; - MATRONICS WEB FORUMS -
ms.matronics.com
; - NEW MATRONICS LIST WIKI -
atronics.com
; - List Contribution Web Site -
; -Matt Dralle, List Admin.
ttp://www.matronics.com/contribution
Posted: Sun Apr 11, 2021 4:32 pm Post subject: Shower of Sparks |
Yes, there are switch breakers. Dennis
| Quote: | On Apr 11, 2021, at 8:30 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
So, the plan is:
Jon
Bill Culberson
251/716/8119
> Jon
mail Forum -
ms.matronics.com
atronics.com
Posted: Sun Apr 11, 2021 4:54 pm Post subject: Shower of Sparks |
Open up the shower of sparks container and you’ll see a set of points next to a thumb wheel. See if the points are “welded” together. If they are, the shower of sparks will not work. If you remove the starting coil wire from the unit and deplete all the air forward of the main air valve (OFF) by squeezing the brake handle until you no longer hear air “whishing” when you release the brake handle, the engine will not rotate or start when you press the start button to see if the points are “arcing” when the start button is pressed.
Dennis
So, the plan is:
Jon
Bill Culberson
251/716/8119
> Jon
mail Forum -
ms.matronics.com
atronics.com
Posted: Sun Apr 11, 2021 7:29 pm Post subject: Shower of Sparks |
Thank you!
Don’t be surprised if you get a call.
| Quote: | On Apr 11, 2021, at 7:58 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
So, the plan is:
Jon
Bill Culberson
251/716/8119
> Jon
mail Forum -
ms.matronics.com
atronics.com
Posted: Mon Apr 12, 2021 2:53 am Post subject: Shower of Sparks |
I'll look forward to speaking with you.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
On 4/11/2021 11:28 PM, Jon Boede wrote:
| Quote: | Thank you!
> is pressed.
> Dennis
> Sent from my iPhone
>> So, the plan is:
>> 1. Replace the circuit breaker
>> 2. Disconnect the two canon plugs to the shower of sparks 2Q and
>> start solenoid 3Q
>> 3. Press the start button and see if that causes the breaker to pop
>> 4. Connect the 3Q canon plug and see if that makes it pop
>> 5. Connect the 2Q canon plug and see if that makes it pop
>> Jon
>> *From:* owner-yak-list-server(at)matronics.com
>> *Sent:* Sunday, April 11, 2021 5:12 PM
>> *To:* yak-list(at)matronics.com <yak-list(at)matronics.com>
>> *Subject:* Re: Shower of Sparks
>> Bill Culberson
>> 251/716/8119
>> sitting.
>> > Jon
>> mail Forum -
>> ms.matronics.com
>> atronics.com
Posted: Mon Apr 12, 2021 8:16 pm Post subject: Shower of Sparks |
Mechanical issue with the circuit breaker. Fixed it. Another gold star for Dennis! (bows to the northeast)
Jon
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Jon Boede <jonboede(at)hotmail.com>
Sent: Sunday, April 11, 2021 10:28 PM
Thank you!
Dennis
So, the plan is:
Jon
Bill Culberson
251/716/8119
> Jon
mail Forum -
ms.matronics.com
atronics.com
draftsjust417(at)gmail.co Guest
Posted: Tue Apr 13, 2021 12:27 am Post subject: Shower of Sparks |
Good to hear of another gremlin exorcised!
Justin
On Mon, Apr 12, 2021 at 9:21 PM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | Mechanical issue with the circuit breaker. Fixed it. Another gold star for Dennis! (bows to the northeast)
Jon
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
To: yak-list(at)matronics.com (yak-list(at)matronics.com) <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Thank you!
| Quote: | On Apr 11, 2021, at 7:58 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
| Quote: | On Apr 11, 2021, at 7:45 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
So, the plan is:
Jon
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of Bill Culberson <migfighter42(at)gmail.com (migfighter42(at)gmail.com)>
--> Yak-List message posted by: Bill Culberson <migfighter42(at)gmail.com (migfighter42(at)gmail.com)>
Bill Culberson
251/716/8119
> On Apr 11, 2021, at 6:10 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
> --> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
> Jon
mail Forum -
ms.matronics.com
atronics.com
n13472(at)aol.com Guest
Posted: Tue Apr 13, 2021 8:25 am Post subject: Shower of Sparks |
You can always tell if it is working if you have your com radio on
the shower of sparks is also a great broad band jammer that you will hear
it breaking squelch on the radio
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Justin Drafts
Sent: Tuesday, April 13, 2021 1:27 AM
Justin
Jon
Thank you!
Dennis
So, the plan is:
Jon
Bill Culberson
251/716/8119
| Quote: | On Apr 11, 2021, at 6:10 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Jon
mail Forum -
ms.matronics.com
atronics.com
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
