Yak-List Digest: 1 Msgs - 03/12/21
dougsappllc(at)gmail.com
PostPosted: Sat Mar 13, 2021 10:28 am    Post subject: Yak-List Digest: 1 Msgs - 03/12/21 Reply with quote
As far as I know the Chinese and Russian brake pads are interchangeable.  I carry the Chinese pads in stock.  Also carry brake assys, these are the complete assy with the break expander tube installed.  In short the assy is everything which fits INSIDE the brake drum.
Shop tip:  The brake pads are sometimes pretty rough and need a bit of clean up to function properly.  The pad must travel freely in and out of the "carrier".  Use a belt sander to clean up any burrs or roughness on the ends and sides (NOT top and bottom) of each pad so that they move freely in and out of the carrier as the brake bladder expands and retracts.  If the pads are not able to move freely individual pads will hang up causing brakes to grab, not release properly and heat up.   Doing this simple procedure will extend the life of both the pad set and your brake drums.
We also carry new brake pads which are slightly oversized, they are (thicker) than new stock pads.  This enables you to get a bit more life out of your brake drums.
Hope this helps,
Doug
On Fri, Mar 12, 2021 at 11:53 PM Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> wrote:
Today's complete Yak-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2021-03-12&Archive=Yak
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2021-03-12&Archive=Yak
                           Yak-List Digest Archive
                     Total Messages Posted Fri 03/12/21: 1
Today's Message Index:
     1. 03:16 PM - Re: 18T Brake Shoes - image  (janeu1000)
________________________________  Message 1  _____________________________________
Time: 03:16:39 PM PST US
Subject: Re: 18T Brake Shoes - image
From: "janeu1000" <jane.woood54321(at)gmail.com (jane.woood54321(at)gmail.com)>
Hmm, I'll take a look near within my locality and hopefully, I'll get a pair of shoes for you. My colleagues work here in a key fob (https://www.minutefob.ca/key-fob-copy-markham) store, they could do my help regarding this issue. Let's see what happens within a short period of time.
http://forums.matronics.com/viewtopic.php?p=500949#500949
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
dhealey(at)precisionaviat
PostPosted: Sun Mar 14, 2021 6:15 am    Post subject: Yak-List Digest: 1 Msgs - 03/12/21 Reply with quote
Does anyone know the paint/ color code for the Yak 52?
On Mar 13, 2021, at 2:55 AM, Yak-List Digest Server <yak-list(at)matronics.com> wrote:
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-03-12&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-03-12&Archive=Yak
