PS
Posted: Sat Mar 06, 2021 7:09 pm Post subject: CJ-6A Question |
I bought a light project CJ recently that had the air system gone thru, check and diverter valves and found the past owner is not mechanical. There are leaks I am chasing down, one had me lost. The belly drain always seems to have pressure on it, what would cause that? QS1?
Kind Regards,
Phil Salter
_________________ Phil
glipaz
Posted: Sun Mar 07, 2021 10:00 am Post subject: Re: CJ-6A Question |
Unlike the firewall snot bottle which only is pressurized by the compressor, the belly snot valve will always be pressurized as long as you have system air pressure. If you shut the main air valve then the belly snot bottle will drain off the residual system pressure.
PS
Posted: Sun Mar 07, 2021 10:10 am Post subject: Re: CJ-6A Question |
Thanks!!
_________________ Phil |
