garyvanremortel(at)gmail. Guest
Posted: Tue Feb 02, 2021 10:14 pm Post subject: Additions to Vic Syracuse's Sport Aviation article this mont |
I sent this to the editor today.
Vic Syracuse did a good job on care and feeding of tires and brakes in the Feb 2021 issue, but please allow me to add my top tips. Change tires and tubes in a clean area of your hangar, so grit and metal chips won’t get trapped between tire carcass and tube. Baby powder contains oils that will attack your tubes, Brown Aircraft EC880 silicone powder is a better choice. Reinstall valve cap right after inflating, so grit doesn’t get into valve causing leaks. New molded seals 154-13000 are superior to oiled felt washers used on common 5” wheels in keeping grit out of bearings. Upgrade Nitrile caliper piston O-rings to Viton or Fluorosilicone for high temperature resistance to compression set. Modern wheel weights are no longer Lead, they are Steel or Zinc and a lot more are needed to balance. MIL-H-5606 fluid has been superseded by fully compatible far less flammable MIL-PRF-87257 fluid. Mobil SHC100 is the Parker Hannifin preferred bearing grease. Use high temperature ceramic grease on anchor pins going into torque plate.
Gary VanRemortel N1GV
Posted: Wed Feb 03, 2021 7:19 pm Post subject: Additions to Vic Syracuse's Sport Aviation article this mont |
I replaced them just on the nosewheel last condition inspection and at the time was unable to find a cross or a discounted price. Maybe one of the EAA chapters near Parker Hannifin Avon, OH could arrange a bulk buy BOGO. They are really nice.
-GV
On Wed, Feb 3, 2021 at 7:02 PM RV6 Flyer <rv6_flyer(at)hotmail.com (rv6_flyer(at)hotmail.com)> wrote:
| Quote: | Where can we get a good price on that 154-13000 seal? They are over $50 each everywhere I looked. Has anyone found a NAPA or other non-aircraft part number that we EXPERIMENTAL type can use?
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
3,400+ Flying Hours NC25, USA
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) <owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)> on behalf of HARRY CROSBY <hcrv6(at)comcast.net (hcrv6(at)comcast.net)>
Sent: Wednesday, February 3, 2021 6:06 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com) <rv-list(at)matronics.com (rv-list(at)matronics.com)>
Subject: Re: Additions to Vic Syracuse's Sport Aviation article this month
Good tips GV, I copied it even if they don't print it. Thanks.
| Quote: | Harry Crosby N16CX On 02/02/2021 10:12 PM Gary VanRemortel <garyvanremortel(at)gmail.com (garyvanremortel(at)gmail.com)> wrote:
Posted: Thu Feb 04, 2021 8:45 pm Post subject: Additions to Vic Syracuse's Sport Aviation article this mont |
Yingling has 154-13000 listed for <$47/ea.
Gary A. Sobek
