rsmith52
Posted: Sun Jan 31, 2021 10:38 am Post subject: LED question |
I am installing dual lightspeed ignitions in my Bearhawk. 5100H1LC LEDs are speced as panel mounts to indicate when one of the ignitions is not powered. The LEDs are powered off a pin on the ignition output connectors. The LEDS are described as 1.8V low current, the red lead is indicated as positive. To test them I used a new AA battery reading 1.6V. I did not get even a faint glow, so wondering if they are bad or if they need the full 1.8V or more to produce visible output.
Rod
kjashton(at)vnet.net Guest
Posted: Sun Jan 31, 2021 11:37 am Post subject: LED question |
The spec says “will operate off 5V to 12V without an external resistor". You just need more juice. See datasheet here https://www.digikey.com/en/products/detail/visual-communications-company-vcc/5100H1LC/59900
-Kent
Quote: | On Jan 31, 2021, at 1:37 PM, Rod Smith <rodsmith52(at)yahoo.com> wrote:
Rod
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Sun Jan 31, 2021 11:45 am Post subject: Re: LED question |
Do NOT test an LED with a battery without a series resistor. Otherwise the
LED will be destroyed. You did not destroy yours because the battery voltage
was not high enough. But if the battery was 1.8 volts or more, the LED would
be destroyed without a series resistor. There are online calculators to
determine the resistor value to use.
_________________ Joe Gores |
user9253
Posted: Sun Jan 31, 2021 11:51 am Post subject: Re: LED question |
I was wrong and Kent is right. The 5100H1LC has a Built-in resistor chip.
But if an LED does not have a built in resistor, then one must be added.
