D-Sub carrying current
rparigoris
PostPosted: Fri Nov 27, 2020 7:33 am    Post subject: D-Sub carrying current Reply with quote
Hi Group Two D-Sub questions: 1) Is it OK to use only 1 D-Sub machined and gold plated pin to carry current to my 5 amp circuit breaker used to control overvoltage on my B&C LR3D regulator (crowbar)? 2) I have another circuit that will carry up to 8 amps. I want to split the load between two D-Sub pins. I remember reading about using a resistor on both pins so the difference in resistance of the two pins would be much closer. Question) what value resistor and how many watt capacity? Thx. Ron P.
PostPosted: Fri Nov 27, 2020 8:43 am    Post subject: D-Sub carrying current Reply with quote
At 09:33 AM 11/27/2020, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
Hi Group Two D-Sub questions: 1) Is it OK to use only 1 D-Sub machined and gold plated pin to carry current to my 5 amp circuit breaker used to control overvoltage on my B&C LRD regulator (crowbar)?
Yes
http://www.aeroelectric.com/Pictures/Schematics/Paralleled_DSub_Pins.pdf
This is a paralleling technique proposed and
approved on the GQM163 SSST target and
later adopted in power distribution components
of the B4000 bizjet.
There are variations on this theme which demand a
few more details on your proposed application.
What are the connections to pins on both
sides of the interface? Are we talking about
a 8A continuous load?
out of that stuff?"
rparigoris
PostPosted: Fri Nov 27, 2020 9:19 am    Post subject: Re: D-Sub carrying current Reply with quote
Hi Bob Thx. for reply. 8 amp continuous load perhaps 10 minutes per flight which is for cooling fans FWF about 30" forward of connector, aft of connector is a switch about 10" away but could easily use 12" of #22 wire. If a resistor were to be used for two wires and 4 amps each, would it need to be rated for 58 watts? I like your 12" of #22 wire solution! Ron P.
rparigoris
PostPosted: Fri Nov 27, 2020 10:21 am    Post subject: Re: D-Sub carrying current Reply with quote
Hi Bob Forget second half of my question, I see you had written mOhms, not ohms. I missed the m. Ron P.
