Get temps
kitfox555(at)sbcglobal.ne
PostPosted: Thu Nov 19, 2020 10:17 pm    Post subject: Get temps Reply with quote
I have a 90 grey head I forgot the temp I should at 5500 rpm 1050. Or 1100 top is 1200 anyone know for sure thanks Jerry. Kitfox 2. 555
genie(at)swissmail.org
PostPosted: Thu Nov 19, 2020 11:42 pm    Post subject: Get temps Reply with quote
Could you please enlighten me on what kind of engine you have on your
Kitfox 2. And on what units you use for temperature. Thank you.
George
PostPosted: Fri Nov 20, 2020 7:16 am    Post subject: Get temps Reply with quote
1990 Rotax 582 two-stroke exhaust gas temperature at the exhaust header
On Nov 19, 2020, at 11:48 PM, George Nielsen <genie(at)swissmail.org> wrote:
Could you please enlighten me on what kind of engine you have on your Kitfox 2. And on what units you use for temperature. Thank you.
George
> Sent from my iPhone
PostPosted: Fri Nov 20, 2020 7:30 am    Post subject: Get temps Reply with quote
In degrees Fahrenheit, I presume.
> George
>> Sent from my iPhone
PostPosted: Fri Nov 20, 2020 7:49 am    Post subject: Get temps Reply with quote
Yes Fahrenheit in degrees
> Sent from my iPhone
>> George
>>> Sent from my iPhone
PostPosted: Fri Nov 20, 2020 7:52 am    Post subject: Get temps Reply with quote
On Nov 20, 2020, at 7:48 AM, Jerold EVANS <kitfox555(at)sbcglobal.net> wrote:
>> Sent from my iPhone
>>> George
>>>> Sent from my iPhone
 Filesize:  1.06 MB
 Viewed:  12522 Time(s)
PostPosted: Fri Nov 20, 2020 8:23 am    Post subject: Get temps Reply with quote
Jerry, allow me to recap the situation: You have a Kitfox 2 with a  1990
Rotax 582 (presumably air cooled) two-cylinder two-stroke engine, you
measure the exhaust gas temperature at the exhaust header and want to
know whether at 5500 rpm the temperature should be 1050 or 1100 or a
maximum of 1200 degrees Fahrenheit. Did I get it right?
>> Sent from my iPhone
>>> George
>>>> Sent from my iPhone
PostPosted: Fri Nov 20, 2020 9:05 am    Post subject: Get temps Reply with quote
Water cooled
On Nov 20, 2020, at 8:29 AM, George Nielsen <genie(at)swissmail.org> wrote:
Jerry, allow me to recap the situation: You have a Kitfox 2 with a 1990 Rotax 582 (presumably air cooled) two-cylinder two-stroke engine, you measure the exhaust gas temperature at the exhaust header and want to know whether at 5500 rpm the temperature should be 1050 or 1100 or a maximum of 1200 degrees Fahrenheit. Did I get it right?
> Sent from my iPhone
>>> Sent from my iPhone
>>>> George
>>>>> Sent from my iPhone
Pat Reilly
PostPosted: Fri Nov 20, 2020 3:33 pm    Post subject: Get temps Reply with quote
Jerold, You have it right. I have the same engine and gages. I just
remember that I'm good until the gage needles go past each other (1200
degrees) on the way up. I don't know if this explanation makes sense to
you. I think the gages were designed that way on purpose.
Pat Reilly
Rocford, IL
On Fri, Nov 20, 2020 at 9:13 AM Jerold EVANS <kitfox555(at)sbcglobal.net>
wrote:
Water cooled
>> Sent from my iPhone
header
>>>> Sent from my iPhone
>>>>> George
