wiring in conduit
bobkuc(at)gmail.com
PostPosted: Mon Nov 02, 2020 7:55 am    Post subject: wiring in conduit Reply with quote
I have a conduit in the wings of my rv-7a.   Wire will be going through it for wingtip lights.  Also in the middle of the right wing I need to add wire for the roll servo and pitot and aoa wires in the left wing.
Do I cut the tube in the middle to separate to add the wires or do I just put a hole in the tube to add the wires?  Is it OK for the wire to be loose in the tube?  And lastly, what do I put in the ends of the tube to prevent chafing of the wires?  I was thinking either fill ends with hot glue or shoe glue or even duct sealant.
Thoughts.
Bob Kuc
finn.usa(at)gmail.com
PostPosted: Mon Nov 02, 2020 9:29 am    Post subject: wiring in conduit Reply with quote
I used the corrugated conduit that Van's sell. I simply made a hole with
a soldering iron (before pulling the wires!)
Actually cut the conduit at the inspection plate to get better access
when riveting the wing skins and installing the bell crank.
Finn
left wing.
Thoughts.
Bob Kuc
PostPosted: Mon Nov 02, 2020 1:44 pm    Post subject: wiring in conduit Reply with quote
A plastic or conduit I presume. A hole is recommended.
In fact, you can make it quite large to facilitate
pulling the wire into the tube. The conduit is simply
for Z-axis support and routing convenience.
Yes
I would put a sleeve of heat shrink over the wire(s)
extending into the conduit 6 inches or so at both
the ends and the mid-tube exit. The things are not
going to 'slide around' in there. Just bevel
the edges of holes/exit points were wires emerge
and buffer the bundles with h-s.
Both wires and conduit are of similar durability/
harness and not antagonistic to each other as long
as there is no forcing . . . and a loose bundle
is not forced. The conduit remains open for future
access.
Goops, goos, glues and other sticky stuffs are to
be applied judiciously and avoided if there are
more elegant choices. We had some really GOOD
goo at Boeing back about 1961 . . . BMS513 . . .
you could retread tires with that stuff. Everybody
hated it for a variety of reasons. Except for
tread sealants on certain plumbing fittings, it was
to be avoided in the TC world.
