speedy11
Joined: 29 Jun 2015 Posts: 62 Location: Port Orange, FL
Posted: Sun Oct 18, 2020 2:10 pm Post subject: RV8-List Digest: 1 Msgs - 10/17/20 |
Ed,
Those cable require regular maintenance. If you don't they will tend to bind. That is true of all cables, not just Van's.
Personally I spray them with Kroil at each annual, and sometime more often. Spraying the outside of the cable housing is sufficient and allow it to creep inside. It is easy to see when it has absorbed inside. There are certain sections of my cables that I can't spray to to limited access, but they are mostly straight sections and thus, less likely to bind.
Stan Sutterfield
Time: 09:42:17 AM PST US
From: edward Clegg <edwclg(at)gmail.com (edwclg(at)gmail.com)>
Subject: Re: RV8-List Digest: 0 Msgs - 10/16/20
Has anyone had problems with the Vans supplied throttle/mixture cables for
RV 8s'?
Both bound up after 8 years, I replaced them and now have an issue with
mixture cables' throw reduced to under 2 inches resulting in inability to
shut a/c down with mixture.
Ed Clegg
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
