John Price
Posted: Fri Oct 23, 2020 1:15 am Post subject: Classic Monowheel Brake Caliper |
Hi All,
It may be me, but the pads seem to be binding on the disk.
I've had the caliper off and changed the o ring, but as the force fro the piston to the pad is not central the unit keeps in contact with the disk as there is no spring to part the two. Has anyone come up wth an Feynman solution to solve this?
TIA.
John.
peterz(at)zutrasoft.com Guest
Posted: Fri Oct 23, 2020 2:27 am Post subject: Classic Monowheel Brake Caliper |
indeed the piston is off-center and ends up jamming due to its wear angle. I have reduced the effect somewhat by trimming some of the inside corners of the piston's pad. It's a lousy design.
-Pete
On Fri, Oct 23, 2020 at 4:24 AM John Price <johnwprice(at)btconnect.com (johnwprice(at)btconnect.com)> wrote:
| Quote: | --> Europa-List message posted by: "John Price" <johnwprice(at)btconnect.com (johnwprice(at)btconnect.com)>
Hi All,
TIA.
John.
http://forums.matronics.com/viewtopic.php?p=498933#498933
Posted: Fri Oct 23, 2020 2:32 am Post subject: Classic Monowheel Brake Caliper |
A Beringer wheel is a good solution albeit a tad expensive. David Joyce, GXSDJ
On 2020-10-23 10:15, John Price wrote: | Quote: | --> Europa-List message posted by: "John Price" <johnwprice(at)btconnect.com (johnwprice(at)btconnect.com)>Hi All,It may be me, but the pads seem to be binding on the disk.I've had the caliper off and changed the o ring, but as the force fro the piston to the pad is not central the unit keeps in contact with the disk as there is no spring to part the two. Has anyone come up wth an Feynman solution to solve this?TIA.John.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=498933#4bsp;--> http://www.matronics.com/Navigator=  f="http://forums.matronics.com" target="_blank" rel="noopener noreferf="http://wiki.matronics.com" target="_blank" rel="noopener noreferre========================http://www.matronics=====================
SPURPURA
Posted: Fri Oct 23, 2020 4:59 am Post subject: Re: Classic Monowheel Brake Caliper |
Grease applied to lube points? It does make a difference.
_________________ N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. |
