mike(at)vision499.com Guest
Dave Saylor
Posted: Thu Oct 15, 2020 7:30 pm Post subject: SLICKSTART Current Draw |
That seems odd. Mine runs off a 3 amp fuse, including the start relay.
There was a bulletin some time back to only run one mag with it. I think it had to do with making sure the left and right systems were completely separate, not really a current draw issue. Maybe though...are you running both mags off a single SlickStart?
--Dave
On Thu, Oct 15, 2020 at 8:15 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Quote: |
I have a Slickstart start unit. Manual calls for a 5 amp fuse but my fuse blows at 5 and 7.5 amp, I have a 12V installation.
Â
Have now installed a 10 amp fuse and all seems to be OK
Â
What could cause the Slickstart to draw more current?
Â
Should I be concerned?
Â
Â
Mike
Virus-free. www.avast.com [url=#m_6967013605755777331_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
_________________ --Dave
KWVI |
mikepienaar09(at)gmail.co Guest
Posted: Thu Oct 15, 2020 7:50 pm Post subject: SLICKSTART Current Draw |
No, I am only connected to the left mag. Right mag is switched off during engine start.
Mike
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of David Saylor
Sent: October 15, 2020 8:26 PM
To: aeroelectric-list <aeroelectric-list(at)matronics.com>
Subject: Re: SLICKSTART Current Draw
--Dave
Mike
Posted: Fri Oct 16, 2020 6:20 am Post subject: SLICKSTART Current Draw |
Quote: | On Thu, Oct 15, 2020 at 8:15 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Mike
Is this a new installation or does it have
a service record on this airplane? Excerpt
from installation manual:
SlickSTART receives input power from the switched positive terminal of the starter motor,
and should be activated only when the starter motor is engaged. During engine
start, SlickSTART draws a maximum of 5 amperes at 6 to 25 volts (P/N SS1001)
and delivers a series of fast rising 375 volt maximum pulses to the primary
of the magneto coil. This voltage is stepped up in the secondary of the coil,
and is impressed across the spark plug electrodes through the magneto distributor
and the high voltage harness.
I think there's something seriously amiss . . .
Posted: Fri Oct 16, 2020 10:37 am Post subject: SLICKSTART Current Draw |
This is a new installation, it is a P/N SS1001 as per the manual. I bought the unit unused from a person that had it on the shelf for more than 15 years, don’t know if that will make a difference. Came in original packing with manual etc. and I don’t think it has been connected peviously.
It is connected to the left magneto on a LOM engine, it is powered directly from the starter solenoid.
I powered the unit directly from the battery, removed the plugs and rotated the engine by hand and it supplied a vey intense spark.
Hope this helps
Mike
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III
Sent: October 16, 2020 7:18 AM
Subject: RE: SLICKSTART Current Draw
Mike |
Posted: Fri Oct 16, 2020 2:13 pm Post subject: SLICKSTART Current Draw |
This may be a duplicate, I sent it this morning but did not see it in my inbox This follows on my previous submission where my SlickStart is blowing 7.5amp fuse.
This is a new installation, it is a P/N SS1001 as per the manual. I bought the unit unused from a person that had it on the shelf for more than 15 years, don’t know if that will make a difference. Came in original packing with manual etc. and I don’t think it has been connected previously.
Hope this helps
Mike
