Yaw servo installation using RV-14 kit
digidocs
PostPosted: Tue Oct 13, 2020 2:04 pm    Post subject: Yaw servo installation using RV-14 kit Reply with quote
Hi list,
Has anyone attempted to install a Garmin yaw servo using the Van's RV-14 yaw servo mounting kit?  Trying to decide whether to go that route or spring for the $550 Garmin kit.  I'm working on a flying airplane, so all fun will be had on hands and knees in the tailcone!
David
robskinner(at)sbcglobal.n
PostPosted: Tue Oct 13, 2020 2:50 pm    Post subject: Yaw servo installation using RV-14 kit Reply with quote
I did. It was easy and works just fine.
Sent from Robert's
On Oct 13, 2020, at 5:16 PM, David Carr <junk(at)dcarr.org> wrote:
Hi list,
David
thebeacoms(at)gmail.com
PostPosted: Tue Oct 13, 2020 3:12 pm    Post subject: Yaw servo installation using RV-14 kit Reply with quote
Same here.
-Dan Beacom
On Oct 13, 2020, at 5:55 PM, Robert Skinner <robskinner(at)sbcglobal.net> wrote:
Sent from Robert's
> Hi list,
> David
Kelly McMullen
PostPosted: Tue Oct 13, 2020 8:24 pm    Post subject: Yaw servo installation using RV-14 kit Reply with quote
I used the Van's kit with a Dynon servo...should make no difference in how the bracket mounts to the airframe. Required minor slotting of two holes on the bracket. The rest was just a bolt it together.
Sent from my TRS-80 Model 100
On Tue, Oct 13, 2020 at 3:54 PM Robert Skinner <robskinner(at)sbcglobal.net (robskinner(at)sbcglobal.net)> wrote:
--> RV10-List message posted by: Robert Skinner <robskinner(at)sbcglobal.net (robskinner(at)sbcglobal.net)>
Sent from Robert's
> On Oct 13, 2020, at 5:16 PM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
> Hi list,
> David
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Vol88
PostPosted: Thu Oct 15, 2020 9:05 am    Post subject: Re: Yaw servo installation using RV-14 kit Reply with quote
I installed the Van's yaw damper kit for Skyview ($160), which does not come with the tiller arm/bow (Garmin may call it a hoop) that connects the rudder cables to the servo. That is another $160 from Dynon. I also read on VAF that Garmin does not sell the hoop separately, only in their $550 kit, although Stein apparently had some hoops in stock.
Someone posted a template to make your own hoop on VAF here: https://vansairforce.net/community/showthread.php?t=153870&page=6
You would still need to buy the Van's yaw damper mount.
Tom
digidocs
PostPosted: Thu Oct 15, 2020 12:53 pm    Post subject: Yaw servo installation using RV-14 kit Reply with quote
Thanks for the help, lots of great experience on this list!
David
On Tue, Oct 13, 2020 at 6:15 PM Dan Beacom <thebeacoms(at)gmail.com (thebeacoms(at)gmail.com)> wrote:
--> RV10-List message posted by: Dan Beacom <thebeacoms(at)gmail.com (thebeacoms(at)gmail.com)>
Same here.
-Dan Beacom
> On Oct 13, 2020, at 5:55 PM, Robert Skinner <robskinner(at)sbcglobal.net (robskinner(at)sbcglobal.net)> wrote:
> Sent from Robert's
>> Hi list,
>> David
WIKI -
