Tr1 Flaps
Keith.Miller(at)esa.int
PostPosted: Wed Sep 23, 2020 12:34 am    Post subject: Tr1 Flaps Reply with quote
On the Tr1 There are individual threaded adjusters to position both flaps tight against the wing root fairings , so that part could be an easy fix . But why this should have changed, or needs adjustment after the initial  build setup should be investigated before making any adjustment . - one possibility, is that the flap torgue activation tube behind the seat is a split tube assembly joined by two bolts at 90 degrees if these have come slightly loose then the holes may have become elongated over time - i am thinking this might be the problem as the left flap is the actual one that is directly connected to the lever and the right  side via the two bolts. See the picture from the build manual .
The important point is the flap angles after they are deployed is the same. so my starting point after making this adjustment is to measure these angle . if they are different then something is wrong with the geometry of the flap attachment points and we can go from there to work out a solution .
(See attached file: flap mechanism.png)
[img]cid:2__=4EBB0F7FDFBBFA6A8f9e8a93df938690(at)esa.int[/img]"jeffbudner" ---22/09/2020 22:38:23-----> KIS-List message posted by: "jeffbudner" <jeffbudner(at)gmail.com> So it appears that the right fla
To: kis-list(at)matronics.com
Date: 22/09/2020 22:38
Subject: Re: Can you identify this TR-1 nose gear?
Sent by: owner-kis-list-server(at)matronics.com
So it appears that the right flap has some kind of slack issue. In the pick below the right flap is fully retracted but is not flush. The left flap is flush. At the trailing edge it appears to be hanging down about 1/2" - 3/4". Took the pick at the end of day and was too tired to think about measuring.
Jeff
http://forums.matronics.com/viewtopic.php?p=498502#498502
http://forums.matronics.com//files/right_wing_flap_564.jpg
matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
MS -
ms.matronics.com">http://forums.matronics.com
.matronics.com">http://wiki.matronics.com
e -
matronics.com/contribution">http://www.matronics.com/contribution
This message is intended only for the recipient(s) named above. It may contain proprietary information and/or
protected content. Any unauthorised disclosure, use, retention or dissemination is prohibited. If you have received
this e-mail in error, please notify the sender immediately. ESA applies appropriate organisational measures to protect
personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo(at)esa.int).
 Filesize:  105 Bytes
 Viewed:  3795 Time(s)
 Filesize:  70.93 KB
