25 amp slow blow fuse
rparigoris
PostPosted: Mon Aug 31, 2020 7:50 pm    Post subject: 25 amp slow blow fuse Reply with quote
Hi Group I need a 25 amp slow blow fuse for my Rotax generator. Anyone know a source? I would prefer something robust like a slow blow ANL fuse that can be mounted on stud. Thx. Ron P.
PostPosted: Tue Sep 01, 2020 7:58 am    Post subject: Re: 25 amp slow blow fuse Reply with quote
There are more than 500 Van's RV-12s flying with Rotax 912ULS eninges.
They all use 30 amp ATC or ATO fuses for the alternator output.
Joe Gores
PostPosted: Tue Sep 01, 2020 1:03 pm    Post subject: 25 amp slow blow fuse Reply with quote
Joe Gores
My recommendation as well. If you want to
install something a bit more robust, you
could step up to the MAXI line of plastic
fuses. The HHX fuseholder has a mounting
hole for mechanically secure installation.
This one comes with 30A fuse already
installed.
https://tinyurl.com/y2htcz4u
. . . but the ATO/ATC fuses have amassed
a good track record in this application
as well.
