richard.goode(at)russiana Guest
Posted: Tue Jun 30, 2020 2:45 am Post subject: MT spring installation |
For those asking instructions to install the stronger governors brings in the Russian R2 governor from Aerometal, our partner in Hungary.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
From: Márczy Marcell <marcell.marczy(at)aerometal.hu>
Sent: 30 June 2020 11:02
To: 'Richard Goode' <richard.goode(at)russianaeros.com>
Subject: MT spring installation
Hi Richard,
First and most important is you can install MT springs only into 4th series governors. You can check the top cap and if “IV” is written then it is a 4th one. (we meet before that it cap itself was 4th one but the governor inside wasn’t .)
To change the bigger spring, you should take of the top cap by the 4 nuts. Then take if off and easily change the spring. On the drawing it is number 21. It is simply standing there, nothing special. Then put back the cap and fix it with the 4 nuts.
To change the smaller spring, you should take out the reduction valve’s nut out on the side. The nut is not on the drawing but it is at number 17 and on the photos as well. Simply change the spring number 12. Then put everything back.
Now, when we do this change, we test the governor on our bench to adjust the spring with the washer number 17.To adjust the oil pressure that needed for the propeller. That’s why the best is doing it at Aerometal, but there is not that big changes in pressure, so the propeller will but blow up, so you can change it, but surly need to check more times before flight.
AEROMETAL Ltd.
EASA Part-145: HU.145.005
Tisztelettel / Best Regards
Marcell Márczy
Chief Engineer
Aerometal Kft.
Ipari Park HRSZ:3508/19
Asbóth Oszkár utca 4.
2038 Sóskút
Hungary
Tel. +36706763869
www.aerometal.hu
[img]cid:image002.jpg(at)01D64ED6.36EB0C70[/img]Please consider the environment before printing.
__________________________________________________________________________________________________________________________________________________________________
Ezen üzenet és annak bármely csatolt anyaga bizalmas, jogi védelem alatt áll, a nyilvános közléstől védett. Az üzenetet kizárólag a címzett, illetve az általa meghatalmazottak használhatják fel. Ha Ön nem az üzenet címzettje, úgy kérjük, hogy telefonon, vagy e-mail-ben értesítse erről az üzenet küldőjét és törölje az üzenetet, valamint annak összes csatolt mellékletét a rendszeréből. Ha Ön nem az üzenet címzettje, abban az esetben tilos az üzenetet vagy annak bármely csatolt mellékletét lemásolnia, elmentenie, az üzenet tartalmát bárkivel közölnie vagy azzal visszaélnie.
This message and any attachment are confidential and are legally privileged. It is intended solely for the use of the individual or entity to whom it is addressed and others authorised to receive it. If you are not the intended recipient, please telephone or email the sender and delete this message and any attachment from your system. Please note that any dissemination, distribution, copying or use of or reliance upon the information contained in and transmitted with this e-mail by or to anyone other than the recipient designated above by the sender is unauthorised and strictly prohibited.
14.79 KB |
4453 Time(s) |
753 Bytes |
4453 Time(s) |
667.36 KB |
4453 Time(s) |
572.32 KB |
4453 Time(s) |
651.98 KB |
4453 Time(s) |
672.47 KB |
4453 Time(s) |
 Download |
| Filename: |
R_2_4thseries.pdf |
271.78 KB |
| Downloaded: |
470 Time(s) |
1906
Posted: Tue Jun 30, 2020 7:21 pm Post subject: Re: MT spring installation |
Many thanks, Richard! This is very helpful.
