pplous(at)aol.com Guest
Posted: Fri Jun 12, 2020 12:14 pm Post subject: A few questions, take 2 |
Matt,
The last attempt came out as random characters. Can we try again? Much obliged.
RV 8 listers, a few questions for your collective wisdom:
1. Did anyone wrap or otherwise protect the SCAT tubing that runs from the right wing NACA inlet to the fresh air vent in the rear seat?
2. How did you route the static air tubing from the bulkhead behind the rear seat to the instrument panel?
3. Did you install instruments or engine/ firewall forward first?
4. Anyone have a good or bad experience with an Advanced Flight Systems panel?
5. If you have rear seat rudder pedals, how did you route the cables around the rear footwells? Any trouble with getting smooth travel?
6. Has anyone used a Dynon AoA pitot tube and static air system with non-Dynon avionics?
7. Can I run coax cables for both VHF comm radios next to each other or do they need separation?
Thanks! Stay safe, sane, and healthy out there.
v/r,
P2
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
bifft(at)xmission.com Guest
Posted: Fri Jun 12, 2020 2:35 pm Post subject: A few questions, take 2 |
Quoting pplous(at)aol.com:
| Quote: | 1. Did anyone wrap or otherwise protect the SCAT tubing that runs
No, figured that the SCAT tubing was enough protection itself. It
isn't carrying fuel or electricity, so the worst that could happen is
it leaks air.
| Quote: | 2. How did you route the static air tubing from the bulkhead behind
Didn't route from the back seat to the instrument panel. The plans
show a forward NACA intake ahead of the panel for the front seat vent.
| Quote: | 3. Did you install instruments or engine/ firewall forward first?
Did engine first and then instruments. Wouldn't have anything to hook
up the engine instruments otherwise.
| Quote: | 4. Anyone have a good or bad experience with an Advanced Flight
Systems panel?
non-Dynon avionics?
None of these apply to my plane.
| Quote: | 7. Can I run coax cables for both VHF comm radios next to each other
Coax is shielded so it should be ok. Checking Aeroelectric
connection I don't find anything recommending against it.
Brian Huffaker, DSWL
RV-8A N609HZ test flying
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 26554 Location: Livermore CA USA
Posted: Fri Jun 12, 2020 3:19 pm Post subject: A few questions, take 2 |
Check out:
http://www.mattsrv8.com
Matt
RV-8 400+ hours
it leaks air.
> Systems panel?
> non-Dynon avionics?
_________________ Matt Dralle
dan.pat.b(at)gmail.com Guest
Posted: Sat Jun 13, 2020 9:40 am Post subject: A few questions, take 2 |
I don’t get to input to very many of these questions - here is one I can comfortably answer: Re question #7 running coax cables together - I have two coax cables (RG400 - the expensive gold stuff) running together to a Garmin 480 and an SL-30 - in nearly 11 years there has never been a problem - important thing is to terminate the cables correctly - if you’re not sure ask for help - and please don’t ask how i know that
Dan Bergeron
11 years and 863 hours on RV-7A - N307TB
No, figured that the SCAT tubing was enough protection itself. It isn't carrying fuel or electricity, so the worst that could happen is it leaks air.
Didn't route from the back seat to the instrument panel. The plans show a forward NACA intake ahead of the panel for the front seat vent.
Did engine first and then instruments. Wouldn't have anything to hook up the engine instruments otherwise.
Coax is shielded so it should be ok. Checking Aeroelectric connection I don't find anything recommending against it.
