Panel Fabrication Was: Re: DC Wiring Diagrams for SPA Panth
iFlyLSA
PostPosted: Mon Feb 15, 2021 9:06 am    Post subject: Panel Fabrication Was: Re: DC Wiring Diagrams for SPA Panth Reply with quote
Rickifly <gambler7425(at)gmail.com (gambler7425(at)gmail.com)>10:55 AM (3 minutes ago)
to aeroelectric-list
Hi Mr Tasker and Group,
Thank you for the feedback of a panel fabricator!
I will give them a call.
This is the Panel, and the quote from EMachineShop was $142.87 delivered (attached).
Reminder: I am a novice and there are many better ways that I have discovered since beginning drafting like adding more relationships and constraints etc.
The drawings are defined accordingly, I just know my drawings will be better as I go
Also available by DM request is the Panel Part in 2D and 3D and GRT 10.1 Sport EFIS Part modeled in Solidworks for fun.
Many Regards,
Rick
On Mon, Feb 15, 2021 at 10:26 AM Dick Tasker <dick(at)thetaskerfamily.com (dick(at)thetaskerfamily.com)> wrote:
I had my panel fabricated by Bill M. of Up North Aviation.  He did a great job for a very reasonable cost.  If you have a design and can supply it in DXF format he can use that directly to cut the panel.  My panel is for an RV9A.  I started with an Affordable Panel when I first built the plane but they went out of business as far as I can find so when I upgraded my panel with more modern electronics, I had to find someone to cut a new panel from scratch.
I found Bill and couldn't have been happier!  Easy to work with and a panel cut perfectly.  His web site has comments about costs and what he can and cannot do.  His price for a complete design and cutout is pretty cheap but if you provide the DXF of your design, it is even less (quite a bit less if my panel was a good example).  I strongly suggest you contact him for a quote.  I suspect you will be pleasantly surprised.  The only thing he does not do is countersinks - but if you have built a plane to the point you need a panel, I am sure you can do those...
Up North Aviation
CNC Instrument Panel Fabrication
WEB           www.upnorthaviation.com
FaceBook    www.facebook.com/upnorthaviation
E-Mail         upnorthaviation(at)gmail.com
Dick Tasker
Rickifly wrote:
I am using the basic student edition of Solidworks. I may invest in the full version if I keep modeling in 3D. It is very easy to learn and now I want a new graphics card and more processors, for those realistic looking models. I completed my first parts in 3D for the airplane: the Panel and the GRT Sport EFIS.  And was able to send the Avionics Panel with cutouts modeled part drawing to EMachineShop for a quote.  They accept Solidworks modeled parts without converting them to a step file or machine file.
EMACHINEPANELRFQ_320046.pdf
 Filename:  EMACHINEPANELRFQ_320046.pdf
 Filesize:  48.94 KB
 Downloaded:  476 Time(s)
PANEL3Dr1.pdf
 Filename:  PANEL3Dr1.pdf
 Filesize:  205.83 KB
 Downloaded:  444 Time(s)
PANEL3Dr1.DWG
 Filename:  PANEL3Dr1.DWG
 Filesize:  24.85 KB
 Downloaded:  434 Time(s)
