tonyrenshaw268(at)gmail.c Guest
Posted: Wed Apr 22, 2020 9:23 pm Post subject: Instrument Panel Advice re placement on Firewall options |
Gidday,
I have my instrument panel such that it sits on small rubber mounts, the type that is a 1/2 wide rubber mount with a flat washer either side, which have centrally located threaded 1/4” shanks out each side. These ones are pretty hard though, hard to tell if they would do much. With these in place my panel will be suspended on them, and sit somewhat on a small soft rubber pad on top of my tunnel. I am wondering if I should be bothered, whether I should ditch this idea and mount the panel to the firewall directly like I believe the instructions dictate. I’m keen on knowing what people think of attempts to isolate the high frequency vibration, whether it's worth the effort. I am going to have an electronic panel as best as I can, and my sub panels screw straight onto lugs on my panel carcass. I’ve also been advised to cut the lip off the top of the panel which I have addressed by building an inverted, internal flange, so I can do this, but other than weight saving I’m wondering if that is a common thing to do. It wouldn’t hurt to put my panel forward an extra 1/2” but it’s not an imperative, and I do already have the mounts attached to the firewall, albeit with nylocs on the engine side, to be changed for conventional nuts before I go too far and forget.
Any tips gratefully accepted.
Tony Renshaw
BobD
Joined: 05 Jan 2016 Posts: 117 Location: Sheffield UK
Posted: Thu Apr 23, 2020 6:39 am Post subject: Re: Instrument Panel Advice re placement on Firewall options |
Hi Tony,
Whilst building, like you, I considered some of the MODS to dampen the vibrations of the Control Panel. However, I decide to follow the instructions from the original build manual, and I am glad that I did, as I have never noticed a problem in the couple of years my aircraft has been flying. Obviously some pilots have had a problem (hence the MODS), but it has been my experience that it is best to build the aircraft as designed, only making changes when experience has proved them necessary.
I have attached a couple of pictures of my panel, one showing the attachment points during the build, and one of the finished article.
103.83 KB |
7272 Time(s) |
112.45 KB |
7272 Time(s) |
_________________ Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 |
dpark748(at)me.com Guest
Posted: Thu Apr 23, 2020 6:53 am Post subject: Instrument Panel Advice re placement on Firewall options |
G-LDVO BUILT AS PER MANUAL NO RUBBER INSTALLED AND NOT HAD A PROBLEM IN 180 hours FLYING.
Dave Park
| Quote: | On 23 Apr 2020, at 06:26, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Gidday,
I have my instrument panel such that it sits on small rubber mounts, the type that is a 1/2 wide rubber mount with a flat washer either side, which have centrally located threaded 1/4” shanks out each side. These ones are pretty hard though, hard to tell if they would do much. With these in place my panel will be suspended on them, and sit somewhat on a small soft rubber pad on top of my tunnel. I am wondering if I should be bothered, whether I should ditch this idea and mount the panel to the firewall directly like I believe the instructions dictate. I’m keen on knowing what people think of attempts to isolate the high frequency vibration, whether it's worth the effort. I am going to have an electronic panel as best as I can, and my sub panels screw straight onto lugs on my panel carcass. I’ve also been advised to cut the lip off the top of the panel which I have addressed by building an inverted, internal flange, so I can do this, but other than weight saving I’m w!
Tony Renshaw
John Wighton
Posted: Thu Apr 23, 2020 11:43 pm Post subject: Re: Instrument Panel Advice re placement on Firewall options |
Mine is hard mounted and 500+ hours, no issues. However, I do not have sub-panels which necessitates the complete removal of the panel whenever l need to work on it. This is not recommended at all unless you are Olga Corbet sized and equally gifted at cockpit gymnastics.
Modification to add 2 x sub-panels is on my bucket list.
_________________ John Wighton
Europa XS trigear G-IPOD |
cakeykev(at)gmail.com Guest
Posted: Fri Apr 24, 2020 9:10 am Post subject: Instrument Panel Advice re placement on Firewall options |
Nearly 1000 hours no problems
Kevin Challis
G ODJG
| Quote: | On 23 Apr 2020, at 06:25, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Gidday,
Tony Renshaw
budyerly@msn.com
Posted: Sun Apr 26, 2020 9:38 am Post subject: Re: Instrument Panel Advice re placement on Firewall options |
In 20 years, I've never needed an isolation mount in a Europa. That said, if you install a 5 cylinder radial for an engine, or you operate off of a washboard for a runway, you may need some. If you can drive your wife's car on the runway without pain or suspension component failure, you'll be fine.
Today's solid state components coupled with the smooth running of the Rotax or Jab engines, and a balanced prop, pretty much makes isolation mounts a thing of the past. Back in the day of spinning gyros and 10 pound instruments I could see it.
Heating is more of a problem with a sealed plastic panel which holds in the heat like a thermos bottle. Please put in a fan or similar to pull the radiated heat from the sun out of the panel.
Today's solid state equipment draws 60 milliamps and don't create heat but the screens do get warm in some components. Especially common in the Dynon Skyview first gen. GRT and Garmin stay somewhat cool. However, a small computer fan on the bottom of the panel and one on top keeps the panel interior at cockpit temp which is good enough.
Always follow the radio manufactuer's recommendations on older salvaged radios. Most older Garmins, like the 430 need an instrument fan.
Keep the panel interface simple and easy to remove. It pays dividends later on.
As far as cables, read my technique article on my website on the throttle and choke cable etiquette. Repairing cables is not worth the cost or time. Any good bike shop can normally make a new set of cables.
Bud Yerly
