Re[2]: Aircraft Tug
gerry.vandyk(at)eastlink.
PostPosted: Sat Apr 11, 2020 3:38 pm    Post subject: Re[2]: Aircraft Tug Reply with quote
If I may suggest, have a look at Minimax Aircraft Tugs for ideas.  https://www.minimaxtugs.com/  They've got a range of light tugs built around cordless drills.
For the bottom end a commercial worm drive gear box would probably be a good bet.  Try searching Ebay for  133ULR20A Browning Raider Worm Gear Reducer.  I'd post a link but it's about 7 miles long.  That unit is seriously overkill for the purpose, but perhaps there's lighter weight similar units.
this might be another option, but you'd need a separate battery and electrical system.
https://www.ebay.com/itm/DC12V-12rpm-Speed-Reduction-Worm-Gear-Motor-with-Cable-70kg-cm-High-Torque/163673951726?hash=item261bba4dee:g:QhkAAOSwOFFeAx2z
Just food for thought
Gerry
