Dan's architecture question
PostPosted: Fri Apr 03, 2020 2:29 pm    Post subject: Dan's architecture question Reply with quote
At 10:49 AM 4/3/2020, you wrote:
--> AeroElectric-List message posted by: "Dan Fritz" <Dfritzj(at)yahoo.com>
Moving this to the correct thread. Anyone see any issues with Bob's
new/proposed architecture for an IO-360 with one mag and one
electronic ignition? Would folks recommend the ignition be on the Battery bus?
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z99P1.pdf
thanks
Bob,
It's been a while since you posted your Z99P1 and I've been having problems posting to the list.
I like your proposed architecture. It appears to be a nice evolutionary step from previous architectures and maintains much of the Z12/8 simplicity. Allowing the backup alternator to bypass the main contactor as you've shown appears to me to provide a fully redundant path to powering the Poly E-bus. I'm running one electronic ignition and one mag on my IO-360 with conventional injection. This Z99P1 looks good for my use.
Have you made a list of your total loads?
How do you plan to use this airplane?
Night? IFR? Long distances over unfriendly
terrain?
Why wouldn't Z13/8 meet your needs with
a lot less fuss?
Dan Fritz
PostPosted: Sat Apr 04, 2020 7:16 am    Post subject: Re: Dan's architecture question Reply with quote
My build is a Velocity which planned for night and IFR flights. Load analysis shows Z13/8 would work fine, just happened to have a 20 Amp alternator already hanging on the engine...
