Some thoughts on 'standby' batteries
PostPosted: Wed Apr 01, 2020 8:00 am    Post subject: Some thoughts on 'standby' batteries Reply with quote
Batteries have been an essential component
of aircraft electrical systems from day-one.
The first airborne electrics were battery powered
by devices recharged after every flight given
that engine driven power sources were not
yet prominent fixtures. Indeed, wind-driven
generators were more prevalent (read low power
and DRAG!).
Batteries were 'wet', produced fumes when
charged. dribbled acid over themselves and
the airplane and had relatively short service
lives. I.e. they were a commodity like tires,
oil and gasoline. Their reliability as a
power source depended on constant monitoring
of condition.
While secondary (rechargeable) batteries have
become much more efficient, environmentally
friendly, more per pound and cubic foot, they
are still a commodity. You cannot install
a battery into any function expecting it to
perform as needed for more than a tiny fraction
of the airframe service life. Further, if loss
of a battery-supported system adversely impacts
probability for comfortable termination of
flight like fuel and oil . . . the battery's
condition demands reliable monitoring of
condition for continued airworthiness.
This is a burden on cost of ownership. It
expands the operator's work load for periodic
and capable preventative maintenance peppered
with the expense of replacement on condition.
Design goals for elegant electrical systems
architecture includes minimizing the need
for batteries in both number, size and expense.
The ultimate achievement for reduction of
batteries might be (1) a battery capable
of but one start cycle and (2) sufficient
capacity to operate landing lights during
the last 60 seconds of a dead-stick landing
at night.
THAT battery might indeed be quite small and
its cost of ownership very nominal. It might
even be cheap enough to simply replace it at
every annual . . . or perhaps every 100 hours
just as you might change the oil. Thus you've
eliminate the need for time, effort and test
equipment necessary to conduct preventative
maintenance on ship's battery(ies).
This line of reasoning sets the design goals
for an electrical system tailored to a project's
engine, airframe, capabilities and planned
missions. One goal is to minimize singling
out any particular set of loads as critical
but to consider the machine, pilot and
flight environment as a system.
Over the past 30 years, a family of architectures
have been proposed, refined, published and
applied to projects in the OBAM aviation
community. Some have served the builder's
design goals well . . . others not so well.
It's an iterative evolutionary process that
strives for demonstrable success.
The proposed Z01 architecture takes into account
the pronounced shift in aircraft designs that
incorporate multiple engine driven power sources,
electrically dependent engines and yes . . .
a desire to shed as much of the battery weight
and cost of ownership as practical.
Discussions here on the List and elsewhere
are needed to ferret out any failure to meet
a design goal . . . not as SUPPLIERS of any
particular electro-whizzy but as USERS
of those devices as components of the whole
FLIGHT SYSTEM.
Peter(at)sportingaero.com
PostPosted: Wed Apr 01, 2020 2:01 pm    Post subject: Some thoughts on 'standby' batteries Reply with quote
Hi Bob,
My last job working for a large blue chip company was part of the design
team for a nuclear submarine. As you can imagine some of the failure
scenarios in the risk register had some fairly catastrophic consequences. As
a result many sub-system owners sought to increase the reliability of their
functions by designing in back-up power supplies. As there was no overall
systems engineering lead (a failure of engineering management as much as
anything else) no-one had the required oversight to spot what was happening.
Before very long there were batteries for everything, with a huge
maintenance overhead (and their own failure scenarios). What was really
required was an electrical power policy at the ship level flowed down to
each sub-system, rather than the sub-systems driving what the ship was
doing. Eventually the high paid help realised what was happening and set in
place a painful (expensive, $$ and time) re-design that ended up having
quite far reaching impacts.
This has a direct parallel to OBAM aircraft. Many of the electro-whizzes on
offer include a back-up battery of some description. As the system design
authority for our own aircraft we have to be sufficiently smart to engineer
in power sources that meet our reliability goals, and not to be dictated to
by sub-system suppliers. That doesn't say back-up batteries in sub-systems
are necessarily bad, just that they have to earn they way onto the aircraft.
As ever the operational goals of the aircraft should dictate the systems
design and equipment selection.
Regards, Peter
PostPosted: Thu Apr 02, 2020 8:03 am    Post subject: Some thoughts on 'standby' batteries Reply with quote
At 04:55 PM 4/1/2020, you wrote:
--> AeroElectric-List message posted by: "Peter Pengilly" <Peter(at)sportingaero.com>
Hi Bob,
<snip>
Yup . . . a story repeated countless times
when legacy systems are burdened with new
requirements for reliability. I try to avoid
that condition for our readers by striving
for architectures that are unlikely to come
up short in the future.
<snip>
Absolutely . . .
Which is why I encourage attention (1) making
every bus 'reliable' and/or (2) not driving
an 'essential' accessory from a minimally
reliable source.
The OBAM aviation supplier cannot
know the technical acumen of every customer
which no doubt drives their decisions/suggestions for
adding batteries. Klaus advocated for
an auxiliary battery to support his LightSpeed
ignition products. The N811HB accident
carried LightSpeed ignition installed contrary
to both Klaus's -AND- AeroElectric recommendations.
He was a defendant in the original filing
of lawsuits but ultimately joined my client
as plaintiff as the technical details of
the case unfolded.
I've often recommended that builders 'follow
the manufacturer's instructions' when the
conversation ponders departure from the
printed instructions. So I'll have to
be mindful of that 'rule' when encouraging
our readers to do their homework such that
departures from instruction are supported
by good science and tribal knowledge.
Thank you for your enduring participation
on the List!
