markdonahue
Joined: 16 Dec 2012 Posts: 16 Location: bainbridge island washington
Posted: Mon Mar 16, 2020 10:42 am Post subject: Radio noise when transmitting |
I have an RV 9A aircraft with a 60 amp Plane Power alternator and an Icom IC-200 radio. I recently installed ADSB (echo UAT/FYX-EXT) with associated antennae at recommended spacing on the plane’s belly. My recent symptoms are a high whine in the headset when transmitting on the radio. I hear incoming radio transmissions clearly. I checked disconnecting the alternator by opening the field circuit breaker and the sound during transmitting goes away.
This issue may be more noticeable while on the ground. When announcing “ready for take-off” I get a response from fellow pilots in the pattern that they hear a high whine in the transmission. However when at 3000 ft altitude and 5 miles from the field during a radio check, the sound in my head set is diminished and the response from fellow pilots is “loud and clear”. The fact that this occurred after the ADSB installation may be unrelated. I don’t remember this problem immediately after that installation, so this may be a canard. Any advice on how to trouble shoot this and recommended fixes that I could attempt.
Thanks to this group. I enjoy and appreciate the knowledge and experience of the members.
Mark Donahue
206 755 1093
_________________ Mark Donahue |
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Mon Mar 16, 2020 3:24 pm Post subject: Re: Radio noise when transmitting |
Make sure that the microphone jacks are electrically insulated from the airframe
with dielectric washers. The mic ground wire should be grounded at the radio end only.
_________________ Joe Gores |
markdonahue
Posted: Mon Mar 16, 2020 6:06 pm Post subject: Re: Radio noise when transmitting |
I spoke to Allen (at) Hartsell (owner of Plane Power now) and he thought it could well be a bad diode on the alternator. Suggested testing between the alternator output to ground with a volt meter set to AC voltage. If I get something closer to 1 volt, as opposed to say .08 volt, then that would show a bad diode. Also suggested checking the grounds. I plan to do that. Thanks for the suggestion on the headphone jacks isolation washers. I will check that also.
Mark
echristley(at)att.net Guest
Posted: Tue Mar 17, 2020 5:09 am Post subject: Radio noise when transmitting |
Also, try adjusting the volume on your headset, if it has a volume control. I had an issue of a squeal on transmit. I think the headset was picking up the transmitted signal and amplifying it back out. Problem went away when I turned the headset volume down
Sent from Yahoo Mail on Android
| Quote: | On Mon, Mar 16, 2020 at 7:27 PM, user9253
<fransew(at)gmail.com> wrote:
Joe Gores
Posted: Tue Mar 17, 2020 9:13 am Post subject: Radio noise when transmitting |
At 01:39 PM 3/16/2020, you wrote:
| Quote: | I have an RV 9A aircraft with a 60 amp Plane Power alternator and an Icom IC-200 radio. I recently installed ADSB (echo UAT/FYX-EXT) with associated antennae at recommended spacing on the plane’s belly. My recent symptoms are a high whine in the headset when transmitting on the radio. I hear incoming radio transmissions clearly. I checked disconnecting the alternator by opening the field circuit breaker and the sound during transmitting goes away.
Mark Donahue
206 755 1093 |
Joe Gores
Joe's suggestion is a good one. Alternator whine
is almost always conducted into transmitted audio
by a ground loop caused by mounting the microphone
jack to airframe without and insulating washer.
https://tinyurl.com/t4kveee
A possible reason for the noise going away while
airborne: Alternator currents flowing on the
airframe are greatest when alternator loads are
heavy. Just after start, the battery is being
recharged which adds to noise source. After
a few minutes recharge, airframe currents
are reduced.
If you already have these washers, then the
hypothesis is moot. Diode failures are rare.
Let us know what you discover.
