Always Hot Power to Injectors and Ignition Coils
echristley(at)att.net
PostPosted: Tue Feb 18, 2020 6:24 am    Post subject: Always Hot Power to Injectors and Ignition Coils Reply with quote
On Tuesday, February 18, 2020, 9:04:57 AM EST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
At 05:10 AM 2/17/2020, you wrote:
Sorry, still not able to post directly.
A couple of questions. How will you do a “mag check� if the coils are always powered?
You don't do a mag check on things that are not
mags . . . If you've got a coil misbehaving
the engine will let you know about it without
any sort of preflight check.
Bob, I can count on one hand the number of times I've disagreed with you, but this is wrong and dangerous. I have dual coils on separate switches, so that I can test each one during a run-up. One uses mechanical points, and the other electronic points. They are both on for take-off and landing, but only one for cruise.
- Six months ago, I noticed a 150rpm drop on one coil. Cleaning the mechanical points cleared it up.
-Three days ago, the engine died when I switched to one of the two. Turned out to be a blown fuse after I had switched out the coil for one of the "magnum power" versions that drew more current.
If you've got dual coils, you will never know that one is misbehaving without the ability to switch the other off.
BTW, I also have two fuel pumps. Both on for take-off and landing, but run-up includes a check that the engine runs fine with either in solo.
johnbright
PostPosted: Tue Feb 18, 2020 2:19 pm    Post subject: Re: Always Hot Power to Injectors and Ignition Coils Reply with quote
BTW, for EFII brand EFI/EI:
    In the case of six cylinder engines, cylinders 5 and 6 top and bottom use the same coilpack. That seems to be a lack of redundancy.
    System 32 uses switches from ECU "P-Leads" to ground to check coilpacks but I would think loss of power to one of those coilpacks in flight would take out cylinders 5 and 6 in the case of six cylinders.
    Legacy systems used SDS ECUs but also have three four-cylinder coilpacks on six cylinder applications whereas SDS branded systems use two six-cylinder coilpacks.
John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links
