Posted: Fri Feb 07, 2020 1:21 pm Post subject: Are Huosai magnetos "handed"? |
Mags are interchangeable left to right/right to left.
Check the high voltage stick for arcing On the sides. This will cause the mag to become inop. Do this b4 you replace the entire mag.
Dennis
| Quote: | On Feb 7, 2020, at 3:27 PM, jay-dub <flyjnw(at)gmail.com> wrote:
I've just had mag failure (number 1) and have managed to source a replacement if necessary. I haven't had chance to diagnose yet so it may just be a short but if it does require replacement, are Huosai mags handed? As in are mag 1 and mag 2 the same or different? The answer determines the next steps.
Thanks.
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=494698#494698
Posted: Fri Feb 07, 2020 1:57 pm Post subject: Are Huosai magnetos "handed"? |
Also make sure the points are opening and closing. If the points don’t open, the mag will be dead.
Dennis
| Quote: | On Feb 7, 2020, at 4:22 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
> Thanks.
> CJ and Yak-52 owner
jay-dub
Posted: Sun Feb 09, 2020 1:51 am Post subject: Re: Are Huosai magnetos |
Thanks Dennis, we will do that. The aircraft is stranded away from base so we want to have parts in place if required to avoid doing multiple journeys.
_________________ CJ owner |
