Switch Selection
Jeff Smith
PostPosted: Tue Oct 24, 2006 2:21 am    Post subject: Switch Selection Reply with quote
Group,
What type of switch do I need (S700-?) in order to get the following function: Off-On-On
I want the "on" positions to power two different set of cabin lights and I only want one set to be on at time.
Jeff
LarryRosen
PostPosted: Tue Oct 24, 2006 4:47 am    Post subject: Switch Selection Reply with quote
Use a S700-X-10 On-On-On and don't connect one of the terminals.
See this section of the connection
<http://www.aeroelectric.com/articles/switches.pdf>
Larry Rosen
RV-10 #356
SMITHBKN(at)aol.com wrote:
Group,
function: Off-On-On
Jeff
Larry Rosen
#40356
N205EN (reserved)
<http>
steerr(at)bellsouth.net
PostPosted: Tue Oct 24, 2006 5:16 am    Post subject: Switch Selection Reply with quote
You can do it with a 2-10 switch - ON-ON-ON. Just don't hook up the bottom ON position. See page 11-19 of the Aeroelectric Connection book.
Bill
nuckollsr(at)cox.net
PostPosted: Tue Oct 24, 2006 5:34 am    Post subject: Switch Selection Reply with quote
At 06:17 AM 10/24/2006 -0400, you wrote:
Group,
function: Off-On-On
S700-2-10 and wired as illustrated in Figure 11-17 of the 'Connection.
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Tue Oct 24, 2006 5:51 am    Post subject: Switch Selection Reply with quote
Gee Larry, I forgot about that posting. Thanks for
stroking the memory!
LarryRosen
PostPosted: Tue Oct 24, 2006 8:11 am    Post subject: Switch Selection Reply with quote
No problem
It is linked from B&C web site in their switch section
<http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?11X358218#s700-1-1>
along with another great article of your on Switch ratings.
here <http://www.aeroelectric.com/articles/swtchrat.pdf>
Larry
Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> <LarryRosen(at)comcast.net>
Larry Rosen
#40356
N205EN (reserved)
<http>
