Fuel gauge and sender wiring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
Aero Siam
PostPosted: Wed Feb 05, 2020 11:05 pm    Post subject: Fuel gauge and sender wiring Reply with quote
Does anyone know how the fuel gauge/sender is wired ? The red/black/ are positive/negative. I presume the yellow and green is the sender but what is the single blue wire on the left side of the sender (that changes to dark green at the gauge) ?
The blue capped terminal on the sender with a lime and a blue wire is ground.
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
 Filesize:  139.49 KB
 Viewed:  12633 Time(s)
 Filesize:  108.85 KB
 Filesize:  67.94 KB
hgmckay
PostPosted: Thu Feb 06, 2020 2:52 pm    Post subject: Fuel gauge and sender wiring Reply with quote
Paul,
Attached are two scanned pages. The first is the wiring diagram for the wiring connection between the fuel sensor and the fuel gage on the panel. The second is a picture of the connections (K2, K3, K4, and V3) on the fuel sensor. There should be four connection points on the back of the fuel gage marked BL (blue), BK (Black), YL (Yellow), RD (red). They are connected to the sensor as shown on the diagram. The red “Low Fuel” light is also connected to the sensor as shown on the diagram. If you have any questions get back with me.
Hugh G. McKay III, P.E. Fellow. L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
http://www.geo.com (click on Power Division)
Sent from Mail for Windows 10
Sent: Thursday, February 6, 2020 2:05 AM
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Subject: Fuel gauge and sender wiring
--> Allegro-List message posted by: "Aero Siam" <paul(at)aero-siam.com>
http://forums.matronics.com/viewtopic.php?p=494670#494670
http://forums.matronics.com//files/2_174.jpg
http://forums.matronics.com//files/3_162.jpg
http://forums.matronics.com//files/7_867.jpg
 Filesize:  70.98 KB
 Viewed:  12625 Time(s)
 Filesize:  88.45 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
