B&C voltage regulator low voltage warning (ADDENDUM)
ceengland7(at)gmail.com
PostPosted: Sun Dec 29, 2019 8:08 pm    Post subject: B&C voltage regulator low voltage warning (ADDENDUM) Reply with quote
There may be a failure to communicate. In the case of a short, the ANL protects the B lead *from* the battery's incredibly high source current. A secondary benefit would be protecting the battery from rapid discharge.
On 12/29/2019 9:35 PM, Pat Little wrote:
Regarding the placement of ANL or other current limiter. If it is to protect the battery—and not the wire—what is the reason to locate it near the battery end?
On Sun, Dec 29, 2019 at 5:23 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
The alternator fuse protects the battery from a shorted "B" lead or alternator.
The fuse should be located near the battery end of the B lead.
A 40 amp ANL or 50 amp Maxi Fuse should work.
https://www.littelfuse.com/~/media/automotive/datasheets/fuses/automotive-fuses/littelfuse_maxi_32v_blade_fuses.pdf
Joe Gores
http://forums.matronics.com/viewtopic.php?p=494095#494095
br> fts!)
r> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
WIKI -
