Yak 52 Air/Oil Separator
greg.barnhard@gmail.com
PostPosted: Sun Dec 15, 2019 4:26 pm    Post subject: Yak 52 Air/Oil Separator Reply with quote
Does anyone know if there are any one-way check valves or flappers in the Yak 52 air/oil separator? I’m looking to set up an engine dehydrator and the best bet seems to be pumping dry air into the breather where it can make its way through the oil tank, case, and exhausts through any open valves in the cylinders. If there are any one way valves/flappers this will obviously not work.
And yes I know the best thing for an engine is to run it regularly...which I do when I’m home. Just hard to do when I’m on a two week or longer trip!
Greg
