Yak-List Digest: 12 Msgs - 10/11/19
yakflyer(at)aol.com
PostPosted: Sat Oct 12, 2019 10:07 am    Post subject: Yak-List Digest: 12 Msgs - 10/11/19 Reply with quote
Has anyone seen Yak 52TW N57AZ? Letters to the registered owner returned as “Unknown - Incorrect Address”.
I bought this Yak new in 2003. Registered it at my resident Airpark... N57AZ.
Interested in buying it back.
Bill Tiley (Tylee)
yakflyer(at)aol.com
On Oct 11, 2019, at 11:51 PM, Yak-List Digest Server <yak-list(at)matronics.com> wrote:
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-10-11&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-10-11&Archive=Yak
Yak-List Digest Archive
Total Messages Posted Fri 10/11/19: 12
Today's Message Index:
1. 02:00 AM - Re: Oil Temp/Oil Press/Fuel Press Triple gauge (727gs)
2. 03:22 AM - Re: Oil Temp/Oil Press/Fuel Press Triple gauge (Harv)
3. 07:09 AM - Re: CJ6 prop blade leakage (Paul Lewis)
4. 09:01 AM - Re: CJ6 prop blade leakage (Larry Pine)
5. 10:57 AM - Re: Oil Temp/Oil Press/Fuel Press Triple gauge (727gs)
6. 11:21 AM - Re: CJ6 prop blade leakage (A. Dennis Savarese)
7. 11:38 AM - Re: CJ6 prop blade leakage (Paul Lewis)
8. 02:26 PM - Re: Re: Oil Temp/Oil Press/Fuel Press Triple gauge (Warren Hill)
9. 02:48 PM - Re: Re: Oil Temp/Oil Press/Fuel Press Triple gauge (Richard Kelley)
10. 05:05 PM - Re: CJ6 prop blade leakage (Paul Lewis)
11. 06:09 PM - Re: CJ6 prop blade leakage (Anthony Savarese)
12. 07:38 PM - Re: CJ6 prop blade leakage (Paul Lewis)
________________________________ Message 1 _____________________________________
Time: 02:00:29 AM PST US
Subject: Re: Oil Temp/Oil Press/Fuel Press Triple gauge
This is a CJ. I forgot to mention it.
I swapped the rear triple gauge with the front and the problem stayed with the
gauge so I'm satisfied that it is the rear gauge. As for the carb temp, I had
an old spare but was unsure if it was any good. Both maxed out high. Couldn't
find the temp probe on the carb, either.
Steve
Steve near Chicago
http://forums.matronics.com/viewtopic.php?p=491766#491766
________________________________ Message 2 _____________________________________
Time: 03:22:56 AM PST US
The air temp probe isn't really part of the carb, is located on the airbox ducting
just behind the air intake mesh filter screen. If you drop the lower engine
cowling you should see it mounted horizontally from the left hand side in the
airbox (as viewed standing in front of the AC)
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=491767#491767
________________________________ Message 3 _____________________________________
Time: 07:09:23 AM PST US
Subject: Re: CJ6 prop blade leakage
Thanks Dennis, do the blades have to be removed to install the seals? My
A&P has no idea.
> On Thu, Oct 10, 2019 at 5:42 PM Anthony Savarese <
> First determine if there is oil inside the hub when you pull the prop hum
> dome and piston. If there is, replace both the inner and outer seal on th
e
> piston.
> Oil inside the hub will spew out on to the blade roots when the prop is
> spinning. Oil inside the hub is caused by a weak inner piston seal.
> Check your log books for the last time the hub was disassembled, cleaned
> and all bearings and races regreased. If it hasn=99t been done in t
he last
> 200 hours, it would be a good idea to do so.
> Also check the log book to see if the collet seals have been replaced in
> the last 600-750 hours. Again, if there is no record of it being done, it
> would be recommended they be replaced as well.
> Dennis
> Sent from my iPhone
>> On Oct 10, 2019, at 10:05 AM, Okanogan Lew <vplewis(at)community.org>
> wrote:
ity.org>
>> Guys, I have noticed a heavy grease seeping from the propeller hub onto
> the blades of on my CJ6. I assume there is a seal that needs to be
> replaced. Any info would be greatly appreciated.
>> http://forums.matronics.com/viewtopic.php?p=491734#491734
________________________________ Message 4 _____________________________________
Time: 09:01:19 AM PST US
> On Oct 11, 2019, at 7:07 AM, Paul Lewis <okanoganlew(at)gmail.com> wrote:
> Thanks Dennis, do the blades have to be removed to install the seals? My A
&P has no idea.
>> On Thu, Oct 10, 2019 at 5:42 PM Anthony Savarese <dsavarese0812(at)bellsouth
.net> wrote:
.net>
dome and piston. If there is, replace both the inner and outer seal on the p
iston.
>> Oil inside the hub will spew out on to the blade roots when the prop is s
>> Check your log books for the last time the hub was disassembled, cleaned a
nd all bearings and races regreased. If it hasn=99t been done in the l
ast 200 hours, it would be a good idea to do so.
>> Also check the log book to see if the collet seals have been replaced in t
he last 600-750 hours. Again, if there is no record of it being done, it wou
>> Dennis
>> Sent from my iPhone
>>> On Oct 10, 2019, at 10:05 AM, Okanogan Lew <vplewis(at)community.org> wrot
e:
ity.org>
the blades of on my CJ6. I assume there is a seal that needs to be replaced
>>> Read this topic online here:
>> List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig
ator?Yak-List
>> FORUMS -
>> eferrer" target="_blank">http://forums.matronics.com
>> WIKI -
>> errer" target="_blank">http://wiki.matronics.com
>> b Site -
>> -Matt Dralle, List Admin.
>> rel="noreferrer" target="_blank">http://www.matronics.com/contributio
n
________________________________ Message 5 _____________________________________
Time: 10:57:27 AM PST US
Are the Chinese and Russian gauges interchangeable?
Steve near Chicago
http://forums.matronics.com/viewtopic.php?p=491774#491774
________________________________ Message 6 _____________________________________
Time: 11:21:57 AM PST US
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
If you're talking about the collet seals, yes.=C2- Then the blade angles
have to be reset.=C2- If you're talking about the seals in the prop hub
piston, no.=C2- To grease the bearings, you loosen the large castellated
nuts on each side and remove the entire assembly from the hub.=C2- What r
emains in the hub is one flat bearing, one race and a slider.=C2- Each si
de is the same.=C2- The other flat bearing is on the assembly you removed
.Dennis
On Friday, October 11, 2019, 10:11:01 AM EDT, Paul Lewis <okanoganlew(at)g
mail.com> wrote:
Thanks Dennis, do the blades have to be removed to install the seals?=C2
- My A&P has no idea.
On Thu, Oct 10, 2019 at 5:42 PM Anthony Savarese <dsavarese0812(at)bellsouth.n
et> wrote:
et>
First determine if there is oil inside the hub when you pull the prop hum d
iston.
Oil inside the hub will spew out on to the blade roots when the prop is spi
nning. Oil inside the hub is caused by a weak inner piston seal.=C2-
Check your log books for the last time the hub was disassembled, cleaned an
Also check the log book to see if the collet seals have been replaced in th
Dennis
> On Oct 10, 2019, at 10:05 AM, Okanogan Lew <vplewis(at)community.org> wrote:
y.org>
> Guys, I have noticed a heavy grease seeping from the propeller hub onto t
he blades of on my CJ6. I assume there is a seal that needs to be replaced.
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigat
or?Yak-List
WIKI -
=C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin.
________________________________ Message 7 _____________________________________
Time: 11:38:30 AM PST US
Very helpful, thanks.
On Fri, Oct 11, 2019 at 11:26 AM A. Dennis Savarese <
> If you're talking about the collet seals, yes. Then the blade angles hav
e
> to be reset. If you're talking about the seals in the prop hub piston,
> no. To grease the bearings, you loosen the large castellated nuts on eac
h
> side and remove the entire assembly from the hub. What remains in the hu
b
> is one flat bearing, one race and a slider. Each side is the same. The
> other flat bearing is on the assembly you removed.
> Dennis
> A&P has no idea.
e
> piston.
he last
> Dennis
> Sent from my iPhone
> wrote:
ity.org>
> http://www.matronics.com/Navigator?Yak-List
> FORUMS -
> WIKI -
> b Site -
n
________________________________ Message 8 _____________________________________
Time: 02:26:38 PM PST US
Subject: Re: Re: Oil Temp/Oil Press/Fuel Press Triple gauge
If you are referring to the triple gauges yes. I have Russian triple gauges in
my CJ and they work fine.
> Steve near Chicago
________________________________ Message 9 _____________________________________
Time: 02:48:26 PM PST US
I have a couple of those gauges at home from my CJ. If you need one call 210-787-0327
>> Steve near Chicago
________________________________ Message 10 ____________________________________
Time: 05:05:50 PM PST US
I have removed one blade. What do you recommend for grease?
> On Fri, Oct 11, 2019 at 11:36 AM Paul Lewis <okanoganlew(at)gmail.com> wrote:
>> have to be reset. If you're talking about the seals in the prop hub
>> piston, no. To grease the bearings, you loosen the large castellated nu
ts
>> on each side and remove the entire assembly from the hub. What remains
in
>> the hub is one flat bearing, one race and a slider. Each side is the
>> same. The other flat bearing is on the assembly you removed.
>> Dennis
y
>> A&P has no idea.
m
he
>> piston.
the last
t
>> Dennis
>> Sent from my iPhone
>> wrote:
nity.org>
o
>> FORUMS -
>> WIKI -
>> b Site -
on
________________________________ Message 11 ____________________________________
Time: 06:09:24 PM PST US
From: Anthony Savarese <dsavarese0812(at)bellsouth.net>
Aeroshell #5 is good.
Dennis
> On Oct 11, 2019, at 8:07 PM, Paul Lewis <okanoganlew(at)gmail.com> wrote:
> =EF=BB
>>> On Fri, Oct 11, 2019 at 11:26 AM A. Dennis Savarese <dsavarese0812(at)bells
ve to be reset. If you're talking about the seals in the prop hub piston, n
o. To grease the bearings, you loosen the large castellated nuts on each si
de and remove the entire assembly from the hub. What remains in the hub is o
ne flat bearing, one race and a slider. Each side is the same. The other f
>>> Dennis
>>> On Friday, October 11, 2019, 10:11:01 AM EDT, Paul Lewis <okanoganlew(at)gm
y A&P has no idea.
h.net> wrote:
h.net>
m dome and piston. If there is, replace both the inner and outer seal on the
piston.
and all bearings and races regreased. If it hasn=99t been done in the
last 200 hours, it would be a good idea to do so.
the last 600-750 hours. Again, if there is no record of it being done, it w
>>> Dennis
>>> Sent from my iPhone
te:
nity.org>
o the blades of on my CJ6. I assume there is a seal that needs to be replace
gator?Yak-List
>>> FORUMS -
>>> WIKI -
>>> b Site -
on
________________________________ Message 12 ____________________________________
Time: 07:38:52 PM PST US
I noticed that the castle nuts on my prop have rows of drilled & tapped
holes, but no screws installed. Photo's of other Housai props show screws
installed & safety wired. Is my CJ missing a prop piece? Thanks.
Paul
On Fri, Oct 11, 2019 at 6:13 PM Anthony Savarese <
> Dennis
> Sent from my iPhone
> =EF=BB
uts
in
>>> Dennis
>>> My A&P has no idea.
>>> hum dome and piston. If there is, replace both the inner and outer seal
on
>>> the piston.
d
the last
n
it
>>> Dennis
>>> Sent from my iPhone
>>> wrote:
unity.org
>>> onto the blades of on my CJ6. I assume there is a seal that needs to be
>>> FORUMS -
>>> WIKI -
>>> b Site -
ion
