saolesen(at)sirentel.net Guest
Posted: Mon Aug 26, 2019 10:56 am Post subject: GNS 480 problems |
My GNS 480 won’t turn on. I’ve checked the wiring to the radio tray and there is the proper voltage at the proper pins. I also attached the 480 to a bench power supply and it turned on just fine. Sliding the radio back in the tray and turning it on there was nothing. So my question is: If I replace the female power and ground pins in the 37 pin dsub will that take care of the problem? I am thinking there is wear at the pin-socket junction. Is there something else I should look at? I have had no problems with the tray and the radio prior to this, so I am looking for some one who has solved the problem before. The plane and radio have 902 hours of use.
I also had transmission problems recently which were resolved by switching from the Bose Lemo plug to the standard jacks and Dave Clarks. I have since switched back and everything is working normally again.
Sheldon Olesen
Posted: Mon Aug 26, 2019 11:08 am Post subject: GNS 480 problems |
If it works on the bench - I would say there's nothing wrong with the 480.
The pins in the tray would be my next investigation point. Make sure you have good power and ground in the tray!
skywagon185(at)gmail.com Guest
Posted: Mon Aug 26, 2019 12:01 pm Post subject: GNS 480 problems |
Sheldon,
If I recall the 480 was not a Garmin product but, is owned by Garmin so I what I will explain is really aimed at GNS430's but, maybe also the 480.
The 430 chassis box is/was very sensitive when installed a bit too far back in the aircraft panel. And, what has happened, is when the 430 is slid into the chassis, some of the pins would not make 100% contact with the chassis pin sockets.
Fix is to loosen the chassis mounting screws and pull it forward such that it's forward edge is even with the instrument panel surface. And, thus, the 430 can now slide a bit further back into chassis and the failing pins will make contact with the chassis socket pin receivers.
Dave
On Mon, Aug 26, 2019 at 11:53 AM saolesen <saolesen(at)sirentel.net (saolesen(at)sirentel.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: saolesen <saolesen(at)sirentel.net (saolesen(at)sirentel.net)>
Sheldon Olesen
Electric-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?AeroElectric-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
ceengland7(at)gmail.com Guest
Posted: Mon Aug 26, 2019 12:52 pm Post subject: GNS 480 problems |
What Dave said, and also check both the pins and their mating socket terminals, to be sure none have backed out of the housing slightly. I really like subD connectors, but failure to fully seat and pins/sockets backing out slightly (often almost undetectable with the naked eye) can both cause problems. I had a similar problem with an old Narco 810, a couple of decades ago.
On 8/26/2019 2:58 PM, skywagon185guy . wrote:
| Quote: | Sheldon,
Dave
Sheldon Olesen
Posted: Tue Aug 27, 2019 2:40 pm Post subject: GNS 480 problems |
Thanks Dave and Charlie. I had a chance to go to the hangar briefly, so I checked the where the tray is placed. It is actually slightly proud on one side and even on the other. I noticed the panel screw was slightly loose so I tightened it , but that didn’t fix the problem. I’ll have more time tomorrow so I’ll check out the pin depth placement. I had the back of the tray off to get a pin in for the position source for the ADS-B out transponder. That may have have moved the pins adversely.
Thanks again!
Sheldon Olesen
| Quote: | On Aug 26, 2019, at 1:53 PM, saolesen <saolesen(at)sirentel.net> wrote:
Sheldon Olesen
