Rick Moss
Posted: Fri Aug 23, 2019 1:13 pm Post subject: Tri-gear brake fluid? |
Evening all; the left brake pedal on my toe-braked tri-gear has gradually started to use more of its travel. Tomorrow I’m going to investigate this (check for leaks, pad/disk wear, master cylinder seals), but as it’s circa 5 years since I last changed the fluid, I cannot recall the type to use! Is it LHM or DOT4?
Thanks in advance
SteveIvell(at)pestproof.c Guest
Posted: Fri Aug 23, 2019 2:32 pm Post subject: Tri-gear brake fluid? |
I think it depends on which brake gear it is....Matco or Jamar.... could be either.
Steve Ivell
Managing Director
Pestproof Ltd.
steveivell(at)pestproof.co.uk
07971 128842
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Rick Moss <Rkwmoss(at)gmail.com>
Sent: Friday, August 23, 2019 10:13:26 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Tri-gear brake fluid?
--> Europa-List message posted by: "Rick Moss" <Rkwmoss(at)gmail.com>
Thanks in advance
http://forums.matronics.com/viewtopic.php?p=491017#491017
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; -Matt Dralle, List Admin.
Rick Moss
spcialeffects
Posted: Sat Aug 24, 2019 1:05 am Post subject: Re: Tri-gear brake fluid? |
It depends on which seals are fitted. Nitrile or buna-n. Nitrile uses dot4 and buna-n uses aero shell (the red transmission fluid stuff).
Frank X, kit #165 mono
SPURPURA
Posted: Sat Aug 24, 2019 2:29 am Post subject: Re: Tri-gear brake fluid? |
What color is it. You don’t want to mix the fluids. DOT5 is purple.
_________________ N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. |
Rick Moss
Posted: Sat Aug 24, 2019 2:54 am Post subject: Re: Tri-gear brake fluid? |
The fluid in it was Aeroshell 41; as a “get home” measure, I’ve emptied that and refilled with LHM as per the manual (mineral hydraulic oil).
Fingers crossed!
Posted: Sat Aug 24, 2019 9:48 am Post subject: Tri-gear brake fluid? |
I always use automatic transmission fluid - ATF.
William Daniell
LONGPORT
On Sat, Aug 24, 2019 at 6:56 AM Rick Moss <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)> wrote:
| Quote: | --> Europa-List message posted by: "Rick Moss" <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)>
Fingers crossed!
http://forums.matronics.com/viewtopic.php?p=491024#491024
FORUMS -
WIKI -
b Site -
brian.davies44(at)gmail.c Guest
Posted: Sat Aug 24, 2019 10:34 am Post subject: Tri-gear brake fluid? |
Aeroshell 41 is an aircraft spec mineral hydraulic oil.
Brian
