chraging problem/symptom
dlm34077(at)gmail.com
PostPosted: Fri Aug 09, 2019 8:22 am    Post subject: chraging problem/symptom Reply with quote
My first instinct was right; It was a beaker but not the field as I thought, after the extra work of removing the cowl and inspecting the engine/alternator without finding a cause I checked voltage directly on the primary bus while running the engine; voltage was 14+. I knew that charging data came from the GRT EIS and was transmitted to the Chelton and GRT Sport via RS232 data. What I did not notice was that while running the engine that  amps were still displayed normally on the Sport but both primary and secondary bus voltages were displaying battery voltage. When I noticed this anomaly I correctly deduced that the master avionics breaker which electrically unites the busses had failed. A 15 minute replacement and all was well.
