connector identification
kenryan
PostPosted: Mon Jul 22, 2019 7:58 am    Post subject: connector identification Reply with quote
Can anyone name the connector in the attached picture? It is on my Optimate TM471 battery charger. The charger comes with two pigtails that can be plugged in (one with ring terminals, one with spring clamps). I wired the ring terminal pigtail to my airframe to allow for easy connection of the charger, without removing the battery. I would like to utilize the spring clamp pigtail for easy connection of a ground power source, but I need the matching connector to set up my power source. Thanks. Ken
 Filesize:  319.86 KB
 Viewed:  8663 Time(s)
ceengland7(at)gmail.com
PostPosted: Mon Jul 22, 2019 8:17 am    Post subject: connector identification Reply with quote
The individual terminal looks like what's in typical tail/brake light
connectors for small trailers. I googled 'trailer connector' & one of
the 1st hits was this:
https://www.delcity.net/store/2-Way-Flat-Connector/p_8873.h_84862.r_IF1003?mkwid=sGlFIIm7H&crid=38094426869&mp_kw=&mp_mt=&gclid=Cj0KCQjwvdXpBRCoARIsAMJSKqIW44OSVL3xnDBzqOwrt2abA-SpQW5cZU6ziMvTlMOP2wCO604p8awaAq2kEALw_wcB
Anyway, that's where I'd start looking.
kenryan
PostPosted: Mon Jul 22, 2019 8:33 am    Post subject: connector identification Reply with quote
Thanks Charlie. We've got a couple of trailer supply shops so I will look there.
On Mon, Jul 22, 2019 at 8:25 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
PostPosted: Mon Jul 22, 2019 9:30 am    Post subject: connector identification Reply with quote
Got a Prime account?
https://www.amazon.com/Hopkins-47965-2-Pole-Flat-Extension/dp/B0002Q80RW
argoldman(at)aol.com
PostPosted: Mon Jul 22, 2019 10:55 am    Post subject: connector identification Reply with quote
If this has been posted before. Forgive me——
Have you considered cutting that connector off and substitute a different one more comparable with your needs?
Rich
<connector.jpg>
JohnCiolino(at)carolina.r
PostPosted: Mon Jul 22, 2019 11:12 am    Post subject: connector identification Reply with quote
Ken,
That connector is called an SAE connector. You can order on Amazon or local trailer shops may have them.
John Ciolino
Bearhawk Patrol
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan
Sent: Monday, July 22, 2019 11:57 AM
Subject: connector identification
dsleepy47
PostPosted: Mon Jul 22, 2019 11:29 am    Post subject: connector identification Reply with quote
Search SAE 2 pin connector on Amazon you should find them for about $2 each if you order a 5 or 6 pack.
Deems
________________________________________
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Ken Ryan <keninalaska(at)gmail.com>
Sent: Monday, July 22, 2019 11:56 AM
dsleepy47
N1491R
kenryan
PostPosted: Mon Jul 22, 2019 12:04 pm    Post subject: connector identification Reply with quote
Thanks!
On Mon, Jul 22, 2019, 11:19 John Ciolino <JohnCiolino(at)carolina.rr.com (JohnCiolino(at)carolina.rr.com)> wrote:
Ken,
John Ciolino
Bearhawk Patrol
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Ken Ryan
John M Tipton
PostPosted: Mon Jul 22, 2019 10:00 pm    Post subject: connector identification Reply with quote
E-bay …
 ----x--O--x----
On 22 Jul 2019, at 8:09 pm, John Ciolino <JohnCiolino(at)carolina.rr.com (JohnCiolino(at)carolina.rr.com)> wrote:
<![endif]--> <![endif]-->
Ken,
John Ciolino
Bearhawk Patrol
