Antenna Ground Plane
PostPosted: Thu Jun 20, 2019 7:43 pm    Post subject: Antenna Ground Plane Reply with quote
At 10:25 AM 6/6/2019, you wrote:
Thank you very much, I look forward to seeing your test results
Keep well
Mike
Mike, if you mounted a Jim Weir ELT
antenna on the side of your fuselage,
how long would the coax need to be to
run from the antenna apex junction
to your ELT?
mike(at)vision499.com
PostPosted: Thu Jun 20, 2019 9:09 pm    Post subject: Antenna Ground Plane Reply with quote
Thanks for your help Bob
Shortest run possible is 1 foot and I can put antenna 5 to 6 ft away on other side of fuselage and run antenna for +/- 8 ft max from current ELT mount. I can reposition the ELT elsewhere in the fuselage but I imagine one does not want then too far apart
Hope this helps
I will be away for 5 days so will not be able to respond
Mike
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III
Sent: June 20, 2019 6:14 PM
Subject: RE: Antenna Ground Plane
Keep well
Mike
to your ELT?
PostPosted: Fri Jun 21, 2019 7:28 am    Post subject: Antenna Ground Plane Reply with quote
Hope this helps
Mike
No problem. The reason I'm asking is
that I'll need to assemble an exemplar
antenna to test . . . but don't have
an airplane of my own.
So, assuming the tests are encouraging,
I'd be pleased to donate the test
article to your project. The factory-fab
coax cables I have for the test would
leave about a 2' flying lead with a
BNC connector on it.
If that would be long enough, then
I think we have a plan for the
testing residuals.
argoldman(at)aol.com
PostPosted: Tue Jun 25, 2019 6:11 am    Post subject: Antenna Ground Plane Reply with quote
Greetings all,
Can a single layer bid carbon layup (of appropriate size) suffice as a ground plane?
Thanks in advance
Rich
On Jun 21, 2019, at 10:26 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Hope this helps
Mike
testing residuals.
PostPosted: Tue Jun 25, 2019 7:30 am    Post subject: Antenna Ground Plane Reply with quote
Bob
Thank you very much
I really appreciate your efforts and would gladly contribute to cover the costs
2 feet would be more than enough
Thanks again
Mike
Sent: June 21, 2019 8:27 AM
Hope this helps
Mike
testing residuals.
PostPosted: Tue Jun 25, 2019 10:32 am    Post subject: Antenna Ground Plane Reply with quote
At 09:10 AM 6/25/2019, you wrote:
Greetings all,
Thanks in advance
Sorry, no. Sheet resistance is too high and making
an electrical connection is problematic. Ground
systems in TC composite a/c are . . . well . . .
I'll be kind: astounding.
PostPosted: Tue Jun 25, 2019 11:42 am    Post subject: Antenna Ground Plane Reply with quote
thanks Bob (now back to the drawing board) Plane(ly)
Rich
