Europa-List: a compass question
duanefamly(at)aol.com
PostPosted: Tue Feb 19, 2019 8:42 pm    Post subject: Europa-List: a compass question Reply with quote
Hey Fred,
While I’m not using the same Navigator compass as you, my compass is mounted centered on top of the instrument panel halfway back from the front edge. The problem that arose once I started flying, and it may only be my problem, is that this area is not very rigid and my compass vibrates…..a lot. Enough so that I added some stiffening to the underside of the instrument module. While it did help, it did not alleviate it completely. I just wanted you be aware prior to your decision as this may have some adverse effects for your compass.
Mike Duane
N377EA Europa XS Conventional Gear
Las Vegas, NV
Sent from Windows Mail
Sent:‎Tuesday‎, ‎February‎ ‎19‎, ‎2019 ‎11‎:‎52‎ ‎AM
To:europa-list(at)matronics.com (europa-list(at)matronics.com)
--> Europa-List message posted by: Fred Klein <freddythek10(at)gmail.com>
Along with my Europa kit, I ordered the “Navigator” compass which was offered as an accessory at the time of purchase.
I ask because the mounting procedure offers little slack…i.e., no second chance...and I want to get it right the first time.
And I’m wondering what that "optimum position” might be…?…
With only “hangar flying” experience, my sense is that the best position would be to mount the adhesive pad provided as high as possible on the windscreen, along the aircraft’s centerline…
A different approach would be to rotate the bracket with the mounting pad and adhere it to the top of the instrument panel module, again on the aircraft centerline…
Or is there, perhaps, another alternative?
Have Europa pilots with in-flight experience settled this question?…or has the digital world eliminated the need or desirability for what’s become a little anachronism?
Advice and counsel appreciated,
Fred
A194
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
