13brv3
Posted: Sun Feb 10, 2019 5:18 am Post subject: Jabiru 2200 installation and flight comments? |
Greetings,
While considering engines for the latest Slingshot project, I ran across the Jabiru 2200 engines. I know Thom had one on a Slingshot, and he seemed happy with the performance. I've heard of a few on Mk-3s as well. Is anyone still flying with a Jabiru? Has anyone flown with the Jabiru 2200 and some other engine on the same plane for comparison? I'd love to see some additional installation pictures, particularly how the exhaust was routed.
FWIW, I'm currently looking at the HKS, Jabiru 2200, and 912. All of these have some pros and cons.
Rusty
brubakermal(at)yahoo.com Guest
Posted: Sun Feb 10, 2019 1:15 pm Post subject: Jabiru 2200 installation and flight comments? |
the HKS is only about as powerful as the rotax 503 the jabiru would be a nice fit for your kolb
Sent from Yahoo Mail on Android
| Quote: | On Sun, Feb 10, 2019 at 8:23 AM, 13brv3
<13brv3(at)gmail.com> wrote:
--> Kolb-List message posted by: "13brv3" <13brv3(at)gmail.com (13brv3(at)gmail.com)>
Greetings,
Rusty
http://forums.matronics.com/viewtopic.php?p=487506#487506
</= Add some info to the Matronics Email List Wiki!
13brv3
Posted: Sun Feb 10, 2019 3:29 pm Post subject: Re: Jabiru 2200 installation and flight comments? |
| brubakermal(at)yahoo.com wrote: | | the HKS is only about as powerful as the rotax 503 the jabiru would be a nice fit for your kolb |
The Jabiru 2200 checks all the boxes for me, but I haven't seen many for sale used, and new isn't an option for any of these engines. The only real installation issue is that the wings won't fold with the standard pusher exhaust config, but I have to believe that can be fixed. Otherwise it's a clean installation, with reportedly good performance despite being direct drive. The other bonus is that the US Jabiru dealer is only about 3 hrs west of me if needed.
The HKS appeal is that it's the lightest, most compact 4-stroke option, as well as being the quietest with the 3.47 gears, and probably the most fuel efficient. My old 503 SS performance wasn't all that bad, but I was young, and feeling the need for speed. Now that I'm getting old, and have proven repeatedly that I won't travel in the plane, I could probably be happier with the lower performance.
Of course the 912 is hands down the most popular option, but they're pricey, heavy, noisy, and require water and oil coolers. The years have taught me to go with the flow a bit more than I used to, but I hate to be too conventional
Rusty
byoungplumbing(at)gmail.c Guest
Posted: Sun Feb 10, 2019 3:51 pm Post subject: Jabiru 2200 installation and flight comments? |
For me the problem with the jabiru is the direct drive. You'll need a shorter prop, which is ok if your plane was designed to fly faster. Say 125 mph or so. The faster turning shorter prop becomes more efficient at higher speeds. The kolbs need a longer slower turning prop too get the most out of the engine horse power.
Boyd
Pfatchantz(at)protonmail. Guest
Posted: Sun Feb 10, 2019 4:00 pm Post subject: Jabiru 2200 installation and flight comments? |
Might do some checking about the cooling of the Jab...I have chatted with tractor and pusher builders and some have mentioned cooling difficulties...Herb
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Sunday, February 10, 2019 5:29 PM, 13brv3 <13brv3(at)gmail.com> wrote:
Rusty
http://forums.matronics.com/viewtopic.php?p=487510#487510
rickofudall
Posted: Sun Feb 10, 2019 4:31 pm Post subject: Jabiru 2200 installation and flight comments? |
Boyd, For what it's worth I've been working on a friend's Zenith 701 with a 2200A Jabby and a two blade Sensenich prop. I set the prop for 3120 RPM static at which it pulls 310 lb. as measured with a digital force gauge. My concern on a Kolb would be the need for a light weight prop. The Sensenich is built similar to the Power Fin, i.e. light and hollow and won't tolerate FOD like a Warp Drive will.
Rick
On Sun, Feb 10, 2019 at 5:53 PM B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
| Quote: | For me the problem with the jabiru is the direct drive. You'll need a shorter prop, which is ok if your plane was designed to fly faster. Say 125 mph or so. The faster turning shorter prop becomes more efficient at higher speeds. The kolbs need a longer slower turning prop too get the most out of the engine horse power.
Boyd
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
13brv3
Posted: Sun Feb 10, 2019 4:33 pm Post subject: Re: Jabiru 2200 installation and flight comments? |
There's precious little data available for Jabiru equipped Kolbs, but I've been exchanging emails with Thom, who owned a Jabiru 2200 Slingshot. He was definitely a fan, and it sounds like it had plenty of performance with the 64" prop he was running. Cooling shrouds are a must, but I wouldn't expect any air cooled engine to have optimum cooling without them.
I've actually been trying to buy an HKS that was up for sale, at a price that would make it worth trying. It doesn't look like that's going to work out though, which may be for the best.
Rusty
zeprep251(at)aol.com Guest
Posted: Sun Feb 10, 2019 7:20 pm Post subject: Jabiru 2200 installation and flight comments? |
Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. Have some Picts I could e mail.
Rusty
http://forums.matronics.com/viewtopic.php?p=487513#487513
13brv3
Posted: Sun Feb 10, 2019 7:30 pm Post subject: Re: Jabiru 2200 installation and flight comments? |
| zeprep251(at)aol.com wrote: | | Have a MK 3C with 2200 Jabiru 1100 hrs ,unusual cooling configuration, no heat problems. Cruise 70mph 2700rpm Sen wood prop 4264 I think, 3150 rpm takeoff. Have some Picts I could e mail. |
That's good to hear. I'd love to see any installation pictures you have.
Rusty
13brv3(at)gmail.com
13brv3
Posted: Mon Feb 11, 2019 3:31 pm Post subject: Re: Jabiru 2200 comments no longer needed :-) |
Thanks for the comments, but fate was working overtime today. I ended up talking with a local pilot, and he mentioned having a 912UL he was planning to sell. Turns out it's a great engine, at a great price, and less than an hour from my house. In a few days, I should be the lucky owner of a 912. Now I need to work on selling my RV-3B so I don't have to sell a kidney or two to pay for this
Rusty
