Garmin Aera660 powered from aircraft bus
PostPosted: Mon Jan 28, 2019 8:44 am    Post subject: Garmin Aera660 powered from aircraft bus Reply with quote
At 04:46 PM 1/26/2019, you wrote:
--> AeroElectric-List message posted by: "John M Tipton" <john(at)tiptonuk.eu>
Hi Bob
I've managed to get hold of a Garmin GPS lead, and the plug that goes into the unit has four pins, two are dormant, the other two are 12v + & -, the cigar plug once dismantled has indeed a glass fuse link, so all good for 12v fused to the aircraft bus.
Which does raise one other question, the fuse looks like 1/4amp, how do I fuse this (and other items like 'steam gauge lighting') which have only light gauge wires, the smallest fuse available for the bus is 1amp
1A will be fine
