				 Posted: Sat Jan 26, 2019 8:24 am    Post subject: Battery disconnect with dual battery   and  trickle charger |
  I bought a 'no name' SLA battery through ebay back in mid November for a Kolb project that won't fly until spring. I just checked its voltage, and it's still at 12.8V. How long do you plan for the plane to sit between flights? While some have had decent luck using 'maintainer' chargers on SLA batteries, many have seen greatly reduced lifespans when using maintainers. If the battery technology doesn't need it (extremely low self-discharge rate), why risk it? Odyssey's technical documents will show you the self-discharge rate for one of their healthy batteries. |
   If you have a demonstrated incident of
   death-by-maintainer, then the maintainer
   was (1) badly designed or (2) defective.
   An 'ideal' recharge/maintenance plot
   looks like this:
   https://tinyurl.com/k6xr9mk
   Here's a measured performance on
   a Schumacher XC75 charger on a
   100AH truck battery
   Here's a plot on a Schumacher WM1562A
   on a 20AH SLVA
   https://tinyurl.com/mtqyhxb
   Here's a Battery Tender Jr. on a 7AH
   SVLA
   https://tinyurl.com/b4td78b
   While some do not closely follow the
   'ideal' plots, they do achieve a top-off
   followed by a drop-and-hold to the
   maintenance level. I've been
   using various charger/maintainer
   products for decades on both vehicles
   and lab batteries with expected
   results: Some of my lab batteries are
   over ten years old and still deliver
   a substantial fraction of their
   name-plate capacity. I.e. still
   over 80%.
   I've yet to test any Harbor Freight
   maintainer that produces the necessary
   performance . . . doesn't mean that
   there are none . . . just that the
   two I tested went into the round-file
   and that was over 10 years ago.
   While it's true that well constructed
   SVLA batteries may not benefit greatly
   from the use of a maintainer, it's
   not a BAD thing to do either and
   in some cases a necessary thing to do.
